Posted: Sun Apr 04, 2010 5:09 pm Post subject: [Probable Spam] 601HD(S): bottom fuse skin |
I remember the problem Carlos,
but the way I resolved it was by looking at the last two bulkheads and
their relative positions. The rudder pivot plates and
extreme forward width required. With a 20mm overlap of these two pieces,
bulkheads in place, or calculated for width,
I believe I made my second tail piece and allowed for the best fit to
align side edges with start of the radius of the standard angle.
Getting proper edge distance using this approach make problems nearly
inconsequential and the sides remain straight.
See attached links.
http://www.macsmachine.com/images/fuselage/full/fusaline.gif
http://www.macsmachine.com/images/fuselage/full/boxframe.gif
Best regards,
Larry McFarland
Carlos Sa wrote:
| Quote: | As I examined the fuselage plans, I noticed the bottom skin sides
aren't straight: where the front (6F1-1) and rear (6F1-2) parts join,
there is an angle.
This raised a concern: as the bottom longeron is straight, won't I
have problems with edge distance when I drill holes on the longeron?
(see attached drawing - obviously not on scale - where the blue part
is 6F1-2, the blue part is 6F1-1 and the longeron is the long blue
rectangle).
Or I could make the bottom ski straight, but this could have a ripple
effect (i.e., 6F1-2 (front H.T. frame) might need to be wider, which
would in turn affect 6F2-6 (rear panel, top) and God know what else...).
I would appreciate any comments from those that have been there (and
still remember).
Carlos
CH601-HD, plans
Montreal, Canada
carlossa52(at)gmail.com Guest
Posted: Sun Apr 04, 2010 8:33 pm Post subject: [Probable Spam] 601HD(S): bottom fuse skin |
Larry, it appears you understood my concern - but I don't understand what you are saying.
Did you position the second tail frame differently from the plans? or did you make a rear bottom skin different from the plans, so the sides of 6F1-1 and -2 make a straight line ? (I don't understand the sentence "The rudder pivot plates and
extreme forward width required.")
Your sentence at the end ("...the sides remain straight.") seems to indicate that you did modify 6F1-1 and/or -2 ...
Thanks for the links to the pictures - I have stared at them for a while, but I don't feel enlightened...
Attached is my modified diagram, now a little closer to the actual proportions of the parts involved.
The red dotted line represents the rivet line.
Thanks for your time and patience...
Carlos
On 4 April 2010 21:06, Larry McFarland <larry(at)macsmachine.com (larry(at)macsmachine.com)> wrote:
| Quote: | --> Zenith-List message posted by: Larry McFarland <larry(at)macsmachine.com (larry(at)macsmachine.com)>
but the way I resolved it was by looking at the last two bulkheads and their relative positions. The rudder pivot plates and
extreme forward width required. With a 20mm overlap of these two pieces, bulkheads in place, or calculated for width,
I believe I made my second tail piece and allowed for the best fit to align side edges with start of the radius of the standard angle.
Getting proper edge distance using this approach make problems nearly inconsequential and the sides remain straight.
See attached links.
Best regards,
Larry McFarland
38.08 KB |
6082 Time(s) |
Posted: Mon Apr 05, 2010 6:25 am Post subject: [Probable Spam] 601HD(S): bottom fuse skin |
Yes, Carlos,
I did remake the bottom tail panel, but only slightly to get a straight
enough shot at proper edge distance. All else seemed to fit when jigged
as per pictures shown. I don't perceive any curve in my tail longerons
at this point. The pics were intended to show setup jigging used
to assess the rear bottom panel and the rest of the assembly. This is a
fairly common arrangement. I remember using quick clamps to grip
the final assembly, so sides might not have been perfectly straight for
drilling and clecoing along that line. Symmetry and centering
used up a lot of ink markers.
As a scratch builder, if I were so good at it, I'd not have had to make
second and third pieces on 30% of my plane to finish it .
Carlos Sa wrote:
| Quote: | Larry, it appears you understood my concern - but I don't understand
Posted: Mon Apr 05, 2010 7:01 am Post subject: [Probable Spam] 601HD(S): bottom fuse skin |
Larry, thanks for the clarification.
I believe I have now enough information to proceed: I'll try to "convince" the longeron to follow the curve first, and if that doesn't work, make a second rear bottom skin. Thankfully aluminum is recyclable...
Thanks to all the replied and offered their thoughts and experience!
Now back to the workbench...
Carlos
CH601-HD, plans
Montreal, Canada
On 5 April 2010 11:24, Larry McFarland <larry(at)macsmachine.com (larry(at)macsmachine.com)> wrote:
[quote]--> Zenith-List message posted by: Larry McFarland <larry(at)macsmachine.com (larry(at)macsmachine.com)>
Yes, Carlos,
I did remake the bottom tail panel, but only slightly to get a straight enough shot at proper edge distance. All else seemed to fit when jigged
as per pictures shown. I don't perceive any curve in my tail longerons at this point. The pics were intended to show setup jigging used
to assess the rear bottom panel and the rest of the assembly. This is a fairly common arrangement. I remember using quick clamps to grip
the final assembly, so sides might not have been perfectly straight for drilling and clecoing along that line. Symmetry and centering
As a scratch builder, if I were so good at it, I'd not have had to make second and third pieces on 30% of my plane to finish it .
Ron Lendon
Joined: 10 Jan 2006 Posts: 685 Location: Clinton Twp., MI
Posted: Mon Apr 05, 2010 5:30 pm Post subject: Re: [Probable Spam] 601HD(S): bottom fuse skin |
Carlos,
Your picture implies the longeron needs to be shaped to fit the sheet metal. I'm not building a HDS but I do have experience shaping L-Angles, formed or extruded. If I'm not understanding the problem, let me know.
_________________ Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
https://sites.google.com/site/corvairenginedata/ |
Posted: Mon Apr 05, 2010 5:44 pm Post subject: [Probable Spam] 601HD(S): bottom fuse skin |
Ron, that seems to be the case, judging from the comments I received.
Carlos
On 5 April 2010 21:31, Ron Lendon <ron.lendon(at)gmail.com (ron.lendon(at)gmail.com)> wrote:
[quote]--> Zenith-List message posted by: "Ron Lendon" <ron.lendon(at)gmail.com (ron.lendon(at)gmail.com)>
Carlos,
Ron Lendon, Clinton Township, MI
Zodiac XL, ScrapBuilder
