Kellym
Posted: Wed Mar 31, 2010 5:45 am Post subject: Hot CHT and fuel flow |
That rule of thumb is just a bit rich. My 200hp fuel injected IO-360
Lycoming flows about 17-18gph on takeoff with EGT and CHT where they
should be....1200-1250 and 340, with a fuel flow unit on EI UBG-16.
16-17 gph should be plenty for 180hp engine.
On 3/31/2010 5:32 AM, Mark Frederick wrote:
| Quote: | "Do you have a way to monitor your Gallons Per Hour? If so do you know
what your putting through on take off? I see about 15 gph on take off
climb. I did slightly enlarge my jet but did not want to go too far."
Rule of thumb applies here: 1 gal for every 10HP (at) sea level (at) full RPM
(at) std temp. If you have a 150HP engine, 15GPH is about right. Look for
18 on a 360 engine.
Another check is to see if you can get 250 ROP at full rated power. If
not, make the appropriate changes.
I suspect more than a few cooling issues are actually fuel related.
Carry on!
Mark
KCHD |
