ianxbrown
Posted: Tue Mar 30, 2010 9:00 am Post subject: High Cyl Head Temps with good baffles |
I had the same problem. Baffles looked great. Engine was fine otherwise. It was solved with a lister's help who referred me to Bart Lalonde at Aerosport Power. My problem was an inadequate main jet orifice. Temps dropped dramatically once I could supply a bit more fuel in the climb. Bart had me send him the jet and he reamed it out a little.
Ian Brown, Bromont, Quebec, RV-9A C-GOHM
bobbyhester(at)newwavecom Guest
Posted: Tue Mar 30, 2010 5:53 pm Post subject: High Cyl Head Temps with good baffles |
Do you have a way to monitor your Gallons Per Hour? If so do you know what your putting through on take off? I see about 15 gph on take off climb. I did slightly enlarge my jet but did not want to go too far.
Ian wrote: [quote] I had the same problem. Baffles looked great. Engine was fine otherwise. It was solved with a lister's help who referred me to Bart Lalonde at Aerosport Power. My problem was an inadequate main jet orifice. Temps dropped dramatically once I could supply a bit more fuel in the climb. Bart had me send him the jet and he reamed it out a little.
Ian Brown, Bromont, Quebec, RV-9A C-GOHM [b]
