f1boss(at)gmail.com Guest
Posted: Wed Mar 31, 2010 4:34 am Post subject: RV-List Digest: 11 Msgs - 03/30/10 |
"Do you have a way to monitor your Gallons Per Hour? If so do you know
what your putting through on take off? I see about 15 gph on take off
climb. I did slightly enlarge my jet but did not want to go too far."
Rule of thumb applies here: 1 gal for every 10HP (at) sea level (at) full RPM (at) std temp. If you have a 150HP engine, 15GPH is about right. Look for 18 on a 360 engine.
Another check is to see if you can get 250 ROP at full rated power. If not, make the appropriate changes.
I suspect more than a few cooling issues are actually fuel related.
Carry on!
Mark
