daveward(at)airward.com Guest
Posted: Tue Mar 30, 2010 1:51 pm Post subject: Main Door Hinges |
AirWard has developed another upgrade kit for the RV-10 line. We have a replacement to the original installation procedure for attaching the main doors to the canopy. So much emphasis has been concentrated on the main door latch system and no consideration for the two hinges holding the main door to the canopy. This 1/8" fiberglass with four countersunk screws is subject to quite a bit of tension when both latching the main door and when the door is in the up position. Our Kit has all the parts for four latches. See the attached brochure for pictures. We also have the Parking Brake Valve Kit and the Tunnel Access Kit available.
Dave Ward
RV-10, just about on gear.
rv10doorhingeflyer.doc |
138 KB |
225 Time(s) |
