dave.saylor.aircrafters(a Guest
Posted: Mon Mar 29, 2010 8:00 pm Post subject: Gear intersection fairing - bonding lower fairing to wheel |
Bill,
I bonded the intersection fairings. I'll try to send some pictures tomorrow, but Lew's pictures tell the whole story. What wasn't intuitive, at least not to me, is that the split line of the intersection fairing has to be forward of the wheel pant split line so the front half of the wheel pant can full forward off the gear leg fairing. Once you start working with it you'll see the problem.
I couldn't tell from Geoff's pictures if he did that too or if he has another solution. Either way, very nice.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Mon, Mar 29, 2010 at 2:29 PM, Bill Mauledriver Watson <MauleDriver(at)nc.rr.com (MauleDriver(at)nc.rr.com)> wrote:
[quote] --> RV10-List message posted by: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com (MauleDriver(at)nc.rr.com)>
I seem to recall that a few people have bonded the lower intersection fairing to the wheel pant but can't remember who. If you've done it and have some pics, please share or point me to them.
It's starting to make some sense to me right now.
Bill "pants on the ground" Watson
http://forums.matronics.com
le, List Admin.
Posted: Tue Mar 30, 2010 10:45 am Post subject: Gear intersection fairing - bonding lower fairing to wheel |
Bill,
Here are some pics of our wheel pants. The gap you see opened up on the inner split line because there isn't a screw closer to the top of the intersection, just the one on the very bottom. Others look nicer so if you can think of some way to pull the split line together you could probably avoid the gap you seen on mine.
Dave Saylor
AirCrafters LLC
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
| Quote: | --> RV10-List message posted by: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com (MauleDriver(at)nc.rr.com)>
le, List Admin.
69.84 KB |
1069 Time(s) |
69.08 KB |
1069 Time(s) |
