NACA Valve Controller
aerosport1
PostPosted: Tue Mar 23, 2010 7:30 pm    Post subject: NACA Valve Controller Reply with quote
Aerosport is proud to annouce its new NACA vent valve controller. This controller was designed to allow the user to adjust the amount of airflow into the overhead consoles that many RV-10 builders are installing. This is really nice when tempatures get below 50 degrees and that cold air is all enclosed, and the overhead is getting pressurized and leaking cold air into the cabin. With this control valve you can totally shut off all air or adjust to wide open all year long. We designed the electronic control unit to accept 12 to 24 volts and it has user end point adjustments, throw reversal and you can reduce the speed in which the valves open and close. The controller installs easily in the instrument panel. It fits 2" scat tubing. We will also have a single valve controller available as well. These valves can be used in many different applications were valve shut offs are needed.
It is very easy to install and comes with everything you will need. Cost has not yet been determined but should be available within 30 days. Keep
checking at http://aerosportproducts.com
 Filesize:  320.91 KB
 Viewed:  2157 Time(s)
 Filesize:  316.48 KB
 Filesize:  280.01 KB
 Viewed:  2150 Time(s)
Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033
