galinhdz(at)gmail.com Guest
Posted: Wed Mar 17, 2010 12:50 pm Post subject: Different 12v Power Jack Option |
For those of us that are looking for a different option instead of just a 12v power jack I found this at a local K-mart for $30.00. It provides a 12vDC "cigarette" jack, two 120vAC ports and a USB power port with iPod adaptor. It is fully self contained to include an on/off switch with LED indicator and a 25ADC fuse in the bottom of the unit so ot can be hard wired to the battery or the main DC bus depending on what you want to do with ist.
With this you get 4 different power connectors in one unit.
[img]cid:ii_1276ddf345c13795[/img]
RALLY 200W Power Converter
[*]Green LED: Power Indicator [*]Red LED: Warning Indicator [*]On/Off Switch [*]iPod Quick Charge Interface Adaptor Included [*]Convenient USB Port [*]DC Port Accessory Socket [*]2 110 Volt AC Recepticles [*]Great cup holder design [*]Built-In cooling fan [*]12v cig lighter plug included [*]2 Year Warranty
Specifications:
[*]Max. Continuous Power: 200 Watt [*]Surge Capability (Peak Power): 400 Watt [*]Output Voltage Range: 110-125 Volt AC RMS [*]Optimum Efficiency: ~ 80% [*]No Load Current Draw: < 300mA [*]Wave Form: Modified Sine Wave [*]Input Voltage Range: 10.5 - 15.0 Volt DC [*]Output Frequency (Hz): 60 Hz (+/- 2 Hz) [*]Replaceable Fuse: 25A [*]High Input Voltage Shutdown: > 15 Volt DC [*]Low Input Voltage Alarm: < 11.5 Volt DC [*]Low Input Voltage Shutdown: < 10.5 Volt DC [*]Dimensions (W x D x H): 6.96 x 3.02 x 3.0 in. [*]Weight: 0.97 lbs.
Galin
N819PR
| | - The Matronics KIS-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
84.71 KB |
2936 Time(s) |
