Annual Condition Inspection
Watkinsdw
PostPosted: Wed Mar 17, 2010 6:06 am    Post subject: Annual Condition Inspection Reply with quote
Hi, Gang,
We're about to conduct our Annual, and could use a little help. We've found an A&P, (since we're not the original builders,) and he has extensive experience w/ building experimentals, but not Kolbs.
We want to make sure he hits all the hot spots and gives the airplane a thorough checkup.
Does anyone have a checklist that you use for the Annual that you are willing to share?
Ours is a MK 3 Classic, finished in 2001. We've got a 912ULS and the plane and engine are right at 600 hours. Steven Green updated the gearbox, having Lockwood add the clutch at about 250 hours. We're burning predominently auto gas, w/ occasional 100LL.
Any help on-list or off-list would be greatly appreciated.
Dave
rickofudall
PostPosted: Wed Mar 17, 2010 8:25 am    Post subject: Annual Condition Inspection Reply with quote
Dave, FAR 43 Appendix D has every item he should cover on the plane. ROAN will have all the latest Service Bulletins and Instructions specific to the engine.While you're airplane is experimental and the TBO requirements do not apply as they would for an S-LSA, you should check to see if your engine is in the serial number range to qualify. Nice thing to have in the logbook, if nothing else. Is he a Rotax mechanic, too? If not, I would be very wary of letting him touch the engine. Check ROAN, but I don't think he can sign off for the TBO increase if he isn't.
Rick Girard
On Wed, Mar 17, 2010 at 9:06 AM, Watkinsdw <david.watkins0(at)gmail.com (david.watkins0(at)gmail.com)> wrote:
[quote] --> Kolb-List message posted by: "Watkinsdw" <david.watkins0(at)gmail.com (david.watkins0(at)gmail.com)>
Hi, Gang,
Dave
http://forums.matronics.com/viewtopic.php?p=290615#290615
le, List Admin.
Ralph B
PostPosted: Wed Mar 17, 2010 9:15 am    Post subject: Re: Annual Condition Inspection Reply with quote
Here's the one I use.
Ralph
annual inspection checklist.doc
 Filename:  annual inspection checklist.doc
 Filesize:  27.5 KB
 Downloaded:  473 Time(s)
Ralph B
Kolb Kolbra 912uls
N20386
550 hours
slyck(at)frontiernet.net
PostPosted: Wed Mar 17, 2010 9:40 am    Post subject: Annual Condition Inspection Reply with quote
I echo Rick's advice on the 912 but, sensible or not, any A&P can sign off your condition inspection regardless of what engine it has on it.Get the signature and then inspect it using common sense.
BB
MkIII, suzuki
yet to pencil whip my logs for the year.
BTW, I have an even more horrible video I could edit for youtube. Should I?
heh heh
Rick Girard
Hi, Gang,
Dave
le, List Admin.
russkinne(at)mac.com
PostPosted: Wed Mar 17, 2010 10:09 am    Post subject: Annual Condition Inspection Reply with quote
Sure, air the video! -- there are some masochists amongst usdo not archive
BB
MkIII, suzuki
heh heh
Rick Girard
Hi, Gang,
Dave
le, List Admin.
Eugene Zimmerman
PostPosted: Wed Mar 17, 2010 4:12 pm    Post subject: Annual Condition Inspection Reply with quote
Ralph,
Good list.
Don't forget to check all cables, cable thimbles and tangs ?
Perhaps you included that and I missed it.
Ralph
Ralph B
Original Firestar 447
N91493 E-AB
1000 hours
23 years flying it
Kolbra 912UL
N20386
2 years flying it
120 hrs
http://forums.matronics.com/viewtopic.php?p=290649#290649
http://forums.matronics.com//files/annual_inspection_checklist_159.doc
Watkinsdw
PostPosted: Sun Mar 21, 2010 2:33 pm    Post subject: Re: Annual Condition Inspection Reply with quote
Thanks, Ralph, this is a great list. Also, "Slyck" and "Eugene."
I'll kick it around with the guy, and double check his Rotax training, shopping around for more help in that area, as needed.
Dave
Watkinsdw
PostPosted: Sun Mar 21, 2010 2:35 pm    Post subject: Re: Annual Condition Inspection Reply with quote
Sorry, I omitted Rick. Good advice, Rick. I'll check the FAR's
Thanks a lot.
Dave
Ralph B
PostPosted: Mon Mar 22, 2010 5:12 am    Post subject: Re: Annual Condition Inspection Reply with quote
Dave
The checklist can be tailored to your aircraft or ultralight to fit your needs. This is what I did when I got it from a guy who flew an Avid Flyer.
Ralph
Ralph B
Kolb Kolbra 912uls
N20386
550 hours
