Posted: Wed Mar 17, 2010 9:46 pm Post subject: Propellers/Propulsers; Propeller Overspeed in Piston Engine |
This notice from the FAA makes a good point. I thought it was worth reading.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
---------- Forwarded message ----------
From: U.S. Federal Aviation Administration Regulatory and Guidance Library <usfaargl(at)service.govdelivery.com (usfaargl(at)service.govdelivery.com)>
Date: Wed, Mar 17, 2010 at 9:34 AM
Subject: Experimental Propellers/Propulsers; Propeller Overspeed in Piston Engine Aircraft - Propellers
To: email(at)aircraftersllc.com (email(at)aircraftersllc.com)
CE-10-21 - Small Airplane/ All/ All Models
You are subscribed to the FAA's GovDelivery service for Airworthiness Directives and Special Airworthiness Information Bulletins, which are also posted in our Regulatory and Guidance Library (RGL) at http://rgl.faa.gov.
This service is provided at no charge. You can update your subscription information at any time on your 9-amc-air140-information-products(at)faa.gov (9-amc-air140-information-products(at)faa.gov).
GovDelivery, Inc. sending on behalf of FAA RGL · 408 St. Peter Street Suite 600 · St. Paul MN 55102 · 1-800-439-1420
| Description: |
 Download |
| Filename: |
ce-10-21.pdf |
| Filesize: |
32.57 KB |
| Downloaded: |
667 Time(s) |
