rv10rob(at)gmail.com Guest
Posted: Mon Mar 15, 2010 11:18 pm Post subject: Rear headset jacks on torque tube covers |
Has anyone mounted their rear headset jacks on the flap torque tube covers, right next to the tunnel? Seems like a good location to me, where the wires don't block the doors and the connectors are out of the way. Anyone have any comments/suggestions?
Thanks..
-Rob
Rob Kochman
RV-10 "Finishing" Kit
Woodinville, WA (near Seattle)
http://kochman.net/N819K
johngoodman
Posted: Tue Mar 16, 2010 5:27 am Post subject: Re: Rear headset jacks on torque tube covers |
Rob,
I don't see anything wrong with it except when you need to remove the cover to take out the front seats. However, I just noticed a post with a mod to the seat rails that would solve that problem.
John
_________________ #40572 Phase One complete in 2011 |
AirMike
Posted: Tue Mar 16, 2010 6:51 am Post subject: Rear headset jacks on torque tube covers |
Put mine on the "armrests" - seemed easier for maintenance.
_________________ See you OSH '18
Q/B - sold. |
Posted: Tue Mar 16, 2010 12:52 pm Post subject: Rear headset jacks on torque tube covers |
Rob Kochman wrote: | Quote: | Has anyone mounted their rear headset jacks on the flap torque tube covers, right next to the tunnel? Seems like a good location to me, where the wires don't block the doors and the connectors are out of the way. Anyone have any comments/suggestions?
| I mounted my HS jacks in the panel (L & R sides like normal) before I changed my mind and mounted them in the tunnel between the seats. I plan on mounting the 't-bar' for the front seats in the forward part of my overhead console and the aft one just above the seat crossbar.
I think putting the HSs down near the floor would subject them to being stepped on ..... or the cords ...... causing damage. I'd rethink that location.
Linn
Thanks..
-Rob
Rob Kochman
| [b]
conradb
Joined: 02 Jun 2008 Posts: 11 Location: warner robins, georgia
Posted: Tue Mar 16, 2010 1:34 pm Post subject: Re: Rear headset jacks on torque tube covers |
Try mounting them in the rear arm rests using the specially designed recessed holder that you can purchase for $16.00 at Spruces.
26.6 KB |
11534 Time(s) |
_________________ Conrad Booze
P. O. Box 7028
Warner Robins, GA. 31095
(478)-335-4264
conradbooze@cox.net |
Jim Combs
Joined: 24 Jan 2010 Posts: 141 Location: Lexington, Ky
Posted: Tue Mar 16, 2010 2:02 pm Post subject: Rear headset jacks on torque tube covers |
I mounted my jacks along with a power plug and entertainment jack (1/8") in the tunnel cover between the seat bottoms.
On Tue, Mar 16, 2010 at 1:42 AM, Rob Kochman <rv10rob(at)gmail.com (rv10rob(at)gmail.com)> wrote:
[quote]Has anyone mounted their rear headset jacks on the flap torque tube covers, right next to the tunnel? Seems like a good location to me, where the wires don't block the doors and the connectors are out of the way. Anyone have any comments/suggestions?
Thanks..
-Rob
Rob Kochman
get="_blank">http://www.matronics.com/Navigator?RV10-List
tp://forums.matronics.com
| [b]
_________________ RV-10 -> N312F - Flying as of 12/2008 |
LarryRosen
Posted: Tue Mar 16, 2010 5:13 pm Post subject: Rear headset jacks on torque tube covers |
Conrad,
Would you share pictures of your installation?
Larry Rosen
conradb wrote:
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
dlm46007(at)cox.net Guest
Posted: Tue Mar 16, 2010 5:14 pm Post subject: Rear headset jacks on torque tube covers |
The torque tube covers need to come off for inspection; do you want to disconnect each time?
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kochman
Sent: Monday, March 15, 2010 10:43 PM
Subject: Rear headset jacks on torque tube covers
Thanks..
-Rob
Rob Kochman
chuck(at)chuckdirect.com Guest
Posted: Wed Mar 17, 2010 12:54 am Post subject: Rear headset jacks on torque tube covers |
122.08 KB |
11510 Time(s) |
conradb
Posted: Wed Mar 17, 2010 12:34 pm Post subject: Re: Rear headset jacks on torque tube covers |
Rob;
Here's a couple of pic's of what I am doing about the rear headphone/mic phone jacks.
Conrad
26.53 KB |
11490 Time(s) |
27.08 KB |
11490 Time(s) |
P. O. Box 7028
(478)-335-4264
Posted: Wed Mar 17, 2010 1:47 pm Post subject: Rear headset jacks on torque tube covers |
Nice installation! I was going to mount mine in the channel above the
panel where you did. I couldn't figure a good place to hang the
headsets where the cords were out of the way of passengers getting
in/out. So I mounted mine in the console cover between the seats.
Linn
conradb wrote:
Posted: Tue Mar 23, 2010 11:59 am Post subject: Rear headset jacks on torque tube covers |
Thanks for the replies. I heard a few potential problems with the torque tube cover location (especially kicking the connectors) and a bunch of other suggestions. My main concern with the armrest location is the blocking of the door access by the headset cords. Does anyone regret putting their jacks on the armrest for that or any other reason?
-Rob
On Mon, Mar 15, 2010 at 10:42 PM, Rob Kochman <rv10rob(at)gmail.com (rv10rob(at)gmail.com)> wrote:
Thanks..
-Rob
Rob Kochman
Rob Kochman
