Lew Gallagher
Joined: 04 Jan 2008 Posts: 402 Location: Greenville , SC
Posted: Mon Mar 15, 2010 5:24 pm Post subject: Wing jacks |
Hey Guys,
Here's another one. I'm in the process of building wing jacks like Tim's and I'm wondering how often you need both wheels off the ground ... would one jack work for almost all wheel repairs, put a scale under one wheel at a time, etc.?
Also, with a flat, does the minimum height of these jacks fit under the wing jack point?
Thanks, - Lew
_________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
gengrumpy(at)aol.com Guest
Posted: Mon Mar 15, 2010 6:02 pm Post subject: Wing jacks |
With some recent history on flats and I have Tim's jacks as well......
There will most likely be times when you need to have both main wheels
off the ground at the same time. You can do this with 2 jacks, or
with 1 jack, have some good, tall wood dunnage you can lower one axle
onto and then move to the other wing and jack it up.
No problem with height of the jack and a flat.....except the nose wheel.
I use my 2 jacks with a 2x4 on top to raise the nose gear off the
ground (put the 2x4 just behind the bulkhead). Works great except
when the nose wheel goes flat.....
I've since put in an anchor in my hangar floor (like Tim did) so that
I can pull down the tail and raise the nose. Works great as long as
the tail is sitting reasonably close to over the anchor.
If I had it to do over again, I would modify Tim's jacks so that they
sit on a flat piece of iron. That extra inch kept me from getting the
2x4 under the fuselage when the nose tire went flat.....
grumpy
On Mar 15, 2010, at 8:24 PM, Lew Gallagher wrote:
Hey Guys,
Thanks, - Lew
non-pilot
Avionics in, engine started!
http://forums.matronics.com/viewtopic.php?p=290397#290397
Jim Berry
Posted: Mon Mar 15, 2010 7:09 pm Post subject: Re: Wing jacks |
Another way to raise the nose wheel is to remove the upper cowl, place a loop of nylon webbing through the upper motor mount tubes, and lift with your engine hoist. It is my understanding that you do not want to use the engine lift point.
Jim Berry
40482
mauledriver(at)nc.rr.com Guest
Posted: Mon Mar 15, 2010 11:55 pm Post subject: Wing jacks |
I don't have wings on but I use 2 nylon web straps under motor mount tubing to lift the front up. Can send a pic or 2 if it will help. Anchoring tail sounds like it will solve problem of having the engine stand rolling around.
-- Sent from my Palm Pre
On Mar 15, 2010 11:09 PM, Jim Berry <jimberry(at)qwest.net> wrote:
--> RV10-List message posted by: "Jim Berry" <jimberry(at)qwest.net>
Jim Berry
40482
http://forums.matronics.com/viewtopic.php?p=290413#290413
Jim Berry
Posted: Tue Mar 16, 2010 11:00 am Post subject: Re: Wing jacks |
I have read, maybe in LightPlane Mainteance, that lifting the plane by the engine strap can crack the crankcase. Fortunately not one of those things that I learned by experience.
Jim Berry
40482
Posted: Tue Mar 16, 2010 11:23 am Post subject: Wing jacks |
Jim Berry wrote:
I wonder why not. the engine mounts/isolators drag the whole airplane
through the air. I've been using the engine strap for a long, long time
... without any bad effects. Maybe I've just 'dodged the bullet'?
Linn
dlm46007(at)cox.net Guest
Posted: Tue Mar 16, 2010 5:14 pm Post subject: Wing jacks |
It always amazes me when people are willing to jack a $150000 aircraft with
a makeshift arrangement. Dropping an aircraft will be expensive in both
dollars and time. Aircraft jacks normally require a hydraulic mechanism for
lifting and a locking mechanism to hold the aircraft if a hydraulic cylinder
fails. I have attached several pictures of the jacks we built to jack high
wing aircraft and low wing aircraft like the RV10. You should be able to see
the hydraulic jacks that are available of the shelf and the additional steel
tubing, large nut and threaded steel rod. On the high wing jacks we use
steel bolts inserted into the tubing to lock in place after the lift. On the
low wing jacks the jacks them selves have a locking mechanism and we simply
welded the tube onto the jack and welded the nut and inserted the threaded
rod. One picture is the moveable tail stand/weight. BTW do not use the
threaded tie down bolt areas as the tapped block does not reach the skin (on
my QB wings) and the Vans supplied jack points will compress the skin of the
wing and eventually crack and break it. On top of the jacks we use wooden
block with baffling material siliconed on to protect the surface. We also
place the jack under the main spar.
92.24 KB |
15358 Time(s) |
107.73 KB |
15358 Time(s) |
98.33 KB |
15358 Time(s) |
Lew Gallagher
Posted: Tue Mar 16, 2010 7:59 pm Post subject: Re: Wing jacks |
Hey David, et al,
That's a sweet jack! I'm on it. Looks like:
https://www.toolsmithonline.com/products.php?product=Powerbuilt%C2%AE-3-Ton-All%252dIn%252dOne-Bottle-Jack%7B47%7DJack-Stand
has the jack/stand. I assume you haven't had any problems with the safety ratchet? A quick google search turned up several complaints of Powerbuilt's regular jack stands failing -- evidently cheaply cast China ratchet.
About the wing tiedown not being flush with the skin: I've made a stud that screws into the tiedown with a shoulder on it so that the weight is on the threads, not the skin -- is that a bad idea? better to spread the weight on the skin?
I'd still like some examples of when both wheels need to be jacked off the ground.
Just a thought about using the engine hoist point to raise the nose wheel: with the engine mounted, the tail acts as a counterweight and the force on the hoist point is less than when lifting the engine by itself ... so what could the problem be?
Later, - Lew
Albert Gardner
Posted: Tue Mar 16, 2010 9:04 pm Post subject: Wing jacks |
I have a 3 blade Aero Composit prop and in order to remove the lower cowl I
have to pull the tail down so the front gear leg can drop down and provide
clearance. I have a 4-wheel HF furniture dolly wilh 180 lbs of concrete mix
on it and a block and tackle that does the job. My wing jacks (I'm glad I
have two) are HF rams in a plywood stand. I drilled a hole for a short piece
of threaded rod that replaces the wing tie-down so the plane can't slip off
of the jack. There is no safety lock on the jack so I block up the axel as
soon as I remove a wheel.
Albert Gardner
N991RV
Yuma, AZ
29.11 KB |
15334 Time(s) |
RV-10 N991RV |
Kelly McMullen
Why mickey mouse with expensive aircraft indeed! You normally will
only need one jack. Here is a high quality jack that I use on my
Mooney that should work on RV-10 by just screwing jack points in place
of tie-down rings:
http://www.aircraft-gse.com/lw-3.html
$180. They have gone up a whopping $30 since I bought mine 10 years ago.
On Tue, Mar 16, 2010 at 5:27 PM, DLM <dlm46007(at)cox.net> wrote:
A&P/IA, EAA Tech Counselor
KCHD |
Albert Gardner
Posted: Wed Mar 17, 2010 12:36 am Post subject: Wing jacks |
Albert Gardner
N9914RV
Yuma, AZ
29.11 KB |
15325 Time(s) |
RV-10 N991RV |
rene(at)felker.com Guest
Posted: Wed Mar 17, 2010 12:50 am Post subject: Wing jacks |
348 lbs for me when I built it. I am in the middle of adding a battery on
the firewall....it should go up aft that.
Rene
801-721-6080
Posted: Wed Mar 17, 2010 6:39 am Post subject: Wing jacks |
I don't remember who posted this, but I did the exact same thing as this but with a welded steel structure. I screw the jack receiver into the tie-down ring base and jack the plane up from there. It is very secure and I am very comfortable with it. I would not use any other system that didn't have the positive connection as I have with the tie-down ring receiver, so there's no way it can fall off the jack.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
On Mar 17, 2010, at 12:36 AM, Albert Gardner wrote:
| Quote: | I have a 3 blade Aero Composit prop and in order to remove the lower cowl I
Albert Gardner
N991RV
Yuma, AZ
<DSC00006 (Small).JPG>
n223rv(at)wolflakeairport Guest
Posted: Wed Mar 17, 2010 8:16 am Post subject: Wing jacks |
I purchased my wing jacks from www.aircraftjacks.com about 3 years
ago. I needed them small enough for my RV-4 and to extend big enough
for my RV-10. They work great and I highly recommend them for long
term maintenance. I also purchased their tail stand for which you add
your own concrete.....
-Mike Kraus
On Mar 16, 2010, at 5:31 PM, "Albert Gardner" <ibspud(at)roadrunner.com>
cowl I
provide
concrete mix
glad I
Albert Gardner
N9914RV
Yuma, AZ
Albert Gardner
Posted: Wed Mar 17, 2010 1:26 pm Post subject: Wing jacks |
Here is how I hold my tail down when needed. Otherwise I roll it into a
corner.
Albert Gardner
N991RV
Yuma, AZ
33.72 KB |
15303 Time(s) |
RV-10 N991RV |
Kelly McMullen
Posted: Wed Mar 17, 2010 3:09 pm Post subject: Wing jacks |
If you attached a fence post of the right length, you could just put a
bolt through to secure the tail from going up or down. With it secure,
jacking on either wing tie down point, or both will raise the nose.
That is how a gear check is done on retractables.
On Wed, Mar 17, 2010 at 3:23 PM, Albert Gardner <ibspud(at)roadrunner.com> wrote:
| Quote: | Here is how I hold my tail down when needed. Otherwise I roll it into a
corner.
Albert Gardner
N991RV
Yuma, AZ
KCHD |
tsts4
Posted: Wed Mar 17, 2010 3:23 pm Post subject: Re: Wing jacks |
Has anyone used this type of jack?
http://www.averytools.com/pc-913-48-the-handy-jack-eldorado-aviation.aspx
8.61 KB |
15288 Time(s) |
9.1 KB |
15284 Time(s) |
_________________ Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying |
coop85(at)verizon.net Guest
Posted: Wed Mar 24, 2010 3:04 pm Post subject: Wing jacks |
If it's just to change the nosewheel, I use a 2x4 levered over a chock with
one end of the 2x4 under the front bearing and then I sit on the other end.
Sounds cheesy but it works great and then I put a block under the fork to
hold while the wheel is removed.
Marcus
40286
Ron B.
Posted: Fri Mar 26, 2010 3:09 pm Post subject: Re: Wing jacks |
Hi.
Anyone know of a Canadian distributor for the Powerbuilt 3 ton all in one?
Thanks Ron
