cjay
Posted: Sat Mar 13, 2010 9:32 am Post subject: fuel pump usage |
Great responses on the approach speed, very helpful. My second item that seems to draw some differing approaches and I suspect there isn't one right answer is the use of the fuel pump.
I've seen some who use it strictly on starting to those that use it liberally in the IMPORTANT zones, i.e., takeoff, descent, approach, landing. I know the latter is for safety, but would love to hear technical reasons why its a good idea.
Also, I've seen some recommend 1-3 seconds on pre start to 3-10 seconds. I suspect the veterans listen to the fuel pressure build up and don't rely on their watch?
Anyone care to share your boost lore?
cjay
robin1(at)mrmoisture.com Guest
Posted: Sat Mar 13, 2010 9:50 am Post subject: fuel pump usage |
For me it's:
<![if !supportLists]>· <![endif]>Takeoff
<![if !supportLists]>· <![endif]>Tank Change
<![if !supportLists]>· <![endif]>(long final) Landing
Regarding starting, my engine likes 5-6 seconds of prime when cold. 10 seconds was too long and 3 seconds was not enough.
Once started (even for 2 minutes) my setup requires a flooded start procedure which seems to work every time.
As you said there may be no one “right” answer but I do PERSONALLY believe there are wrong answers like not using the boost pump of takeoff and short final.
Robin
dlm46007(at)cox.net Guest
Posted: Sat Mar 13, 2010 9:53 am Post subject: fuel pump usage |
Hot starts are: throttle cracked, mixture idle cutoff, boost pump on, starter, enrichen as it fires, release starter to both.
Flooded start are mixture idle cutoff, ignition off, throttle full, crank at least three blades then hot start.
robertbrunk(at)mac.com Guest
Posted: Sat Mar 13, 2010 12:50 pm Post subject: fuel pump usage |
I operate pump until flow meter shows rate of flowat start up then
turn it off. I do use it each time I change tanks every 30 minutes.
Then off again. That is it. Robert
Robert E. Brunkenhoefer
Brunkenhoefer Law Firm, P.C.
606 N. Carancahua Street
Suite 1200
Corpus Christi, Texas 78476
Phone: 361-888-8808
Facsimile: 361-888-6753
robert(at)brunklaw.com
cjay
http://forums.matronics.com/viewtopic.php?p=290199#290199
Posted: Sat Mar 13, 2010 1:50 pm Post subject: fuel pump usage |
Truth be told I don't always use it on tank changes. Just left over
(good) habit from my trainer days. I never saw the downside to this
procedure.
Robin
Posted: Sat Mar 13, 2010 3:52 pm Post subject: fuel pump usage |
Besides starting, the boost pump provides fuel pressure to keep the engine
running in the event of a mechanical pump failure. A fuel injected engine
won't produce power without fuel pressure from the mechanical and/or boost
pump.
Everyone gets to decide for themselves when they would LEAST like an engine
failure, so you hear different scenarios for using the boost pump. I turn
it on for take-off to cruise, and as part of my Gas-Mixture-Prop-Pump check
for landing. I'm not sure what the reasoning would be for turning it on to
switch tanks, but it can't hurt.
ronrvbuilder(at)bigpond.c Guest
Posted: Sun Mar 14, 2010 3:52 am Post subject: fuel pump usage |
I’ve also read some articles about making sure that you have maximum fuel flow during takeoff to ensure adequate cylinder cooling. Using the boost pump is supposed to help achieve this.
Cheers
Ron
VH-XRM flying in Oz
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robin Marks
Sent: Sunday, 14 March 2010 4:46 AM
Subject: RE: fuel pump usage
For me it's:
Robin
-----Original Message-----
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of cjay
Sent: Saturday, March 13, 2010 9:33 AM
Subject: fuel pump usage
--> RV10-List message posted by: "cjay" <cgfinney(at)yahoo.com>
cjay
to browse
Un/Subscription,
Browse, Chat, FAQ,
more:
Web Forums!
support!
Kellym
Posted: Sun Mar 14, 2010 6:50 am Post subject: fuel pump usage |
Actually, use of the boost pump will have virtually no effect on your
fuel flow for takeoff. Your fuel servo delivers fuel pressure to the
nozzles based on the impact air hitting the tubes in the intake, e.g.
mass airflow. Whether you deliver minimum fuel pressure required or
maximum pressure allowed to the servo, it is going to deliver the same
pressure to the nozzles if it is working correctly. The boost pump is
unlikely to increase the pressure delivered by more than 10% of total
pressure..e.g. from 24 to 26, not a big change.
On 3/14/2010 2:28 AM, Ron McGann wrote:
[quote] I’ve also read some articles about making sure that you have maximum
Cheers
Ron
VH-XRM flying in Oz
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Robin Marks
*Sent:* Sunday, 14 March 2010 4:46 AM
*To:* rv10-list(at)matronics.com
*Subject:* RE: fuel pump usage
For me it's:
· Takeoff
· Tank Change
· (long final) Landing
and short final.
Robin
KCHD |
