Blue rivets
Afterfxllc(at)aol.com
PostPosted: Sat Mar 13, 2010 6:59 pm    Post subject: Blue rivets Reply with quote
I don't know what I am doing wrong but almost all of my rivets I drive are turning BLUE and I am using the ones Zenith Supplied. Is anyone else having this problem?
Jeff
 Filesize:  45.97 KB
 Viewed:  4622 Time(s)
mark(at)macomb.com
PostPosted: Sat Mar 13, 2010 7:54 pm    Post subject: Blue rivets Reply with quote
John Bolding
PostPosted: Sun Mar 14, 2010 4:41 am    Post subject: Blue rivets Reply with quote
carlossa52(at)gmail.com
PostPosted: Sun Mar 14, 2010 7:50 am    Post subject: Blue rivets Reply with quote
Never seen that - are you sure they aren't they explosive bolts?
Carlos
CH601-HD, plans
On 13 March 2010 22:52, <Afterfxllc(at)aol.com (Afterfxllc(at)aol.com)> wrote:
[quote] I don't know what I am doing wrong but almost all of my rivets I drive are turning BLUE and I am using the ones Zenith Supplied. Is anyone else having this problem?
Jeff
Z601c(at)anemicaardvark.c
PostPosted: Sun Mar 14, 2010 8:51 am    Post subject: Blue rivets Reply with quote
this problem?
No, nor have I ever heard of a rivet turning blue. The act of setting a rivet
of this kind generates a fair amount of heat internal to the rivet, which
makes me wonder if this is some odd sort of chemical reaction.
Did the rivet turn blue immediately after you set it, or did it wait a while -
perhaps the same length of time it would take the rivet to cool? It's probably
a silly question, but did you soak or coat the rivet with anything, or store
them near a reactive chemical?
Jim B. Belcher
BS,MS Physics
A&P/IA
General Radio Telephone Certificate
Instrument Rated Pilot
Retired Aerospace Technical Manager
Semi-proficient Househusband
PostPosted: Sun Mar 14, 2010 8:54 am    Post subject: Blue rivets Reply with quote
this problem?
Jeff, after chewing on this a bit, I have suggestion/offer. I bunged up a few
rivets while setting them, and have some extras. None of mine turned blue.
If you're in the CONUS, I could mail you a few of mine to try. If you set them
and they turn blue, there's something in the process you're using. If they
don't, there's some difference in the rivets, and you might want to think about
getting some more rivets.
Jim B. Belcher
BS,MS Physics
A&P/IA
PostPosted: Sun Mar 14, 2010 9:53 am    Post subject: Blue rivets Reply with quote
On Sunday 14 March 2010 11:50:48 you wrote:
<Z601c(at)anemicaardvark.com>
few rivets while setting them, and have some extras. None of mine turned
blue.
I should clarify - I bought a bunch more rivets.
them and they turn blue, there's something in the process you're using. If
they don't, there's some difference in the rivets, and you might want to
think about getting some more rivets.
Jim B. Belcher
BS,MS Physics
A&P/IA
