Question about Ground Adj. Props
fklein(at)orcasonline.com
PostPosted: Sat Mar 13, 2010 8:49 am    Post subject: Question about Ground Adj. Props Reply with quote
FWIW, Sensenich does offer a 3 blade composite ground adjustable prop
for the 9XX designated 3BOR5R68C, weight 10 lbs., min. diameter of 64".
Alas, the shanks of the 2 blade prop they make for the Jab 3300 relies
on a different hub design and do not fit in the 3 blade-hub.
Fred
show_brochure_english.pdf
 Filename:  show_brochure_english.pdf
 Filesize:  236.03 KB
 Downloaded:  260 Time(s)
PostPosted: Sat Mar 13, 2010 9:05 am    Post subject: Question about Ground Adj. props Reply with quote
64"...max. rpm of 2700.
I have a pdf which apparently won't post to the list...happy to send
it to anyone who'd like to see it...the Powersweep 3 blade is indeed a
thing of beauty.
Fred
grahamsingleton(at)btinte
PostPosted: Sat Mar 13, 2010 9:37 am    Post subject: Question about Ground Adj. Props Reply with quote
Fred
that does look beautiful! Is the rear face of the section slightly concave? That would really convince me.
Graham
Sent: Saturday, 13 March, 2010 16:04:42
Subject: Question about Ground Adj. Props
FWIW, Sensenich does offer a 3 blade composite ground adjustable prop for the 9XX designated 3BOR5R68C, weight 10 lbs., min. diameter of 64".
Alas, the shanks of the 2 blade prop they make for the Jab 3300 relies on a different hub design and do not fit in the 3 blade-hub.
Fred
