occom
Posted: Wed Mar 10, 2010 6:23 pm Post subject: help--how to mount wingtips. |
My new wingtips have arrived and I'm very pleased. Unfortunately I need someone to forward mounting instructions. On my 1991-2 Model IV 1050 the original wingtip instructions showed them pop riveted to the last rib, and a fabric finish tape over the joint.
The new hit came with aluminum strips and from pictures posted here the other day I guess they are riveted (and glued) to the outer side of the rib on the inside of the capstrip. Then the wingtip is screwed to nutplates mounted on the strips?
This is what I have guessed but a set of real instructions and pictures would help with rivets/bolt pitches etc.
Hoping for help, thanks.
Dave Goddard
KF IV 1050 / 582 / Warp
Guy Buchanan
Posted: Wed Mar 10, 2010 9:04 pm Post subject: help--how to mount wingtips. |
At 06:19 PM 3/10/2010, you wrote:
| Quote: | | The new hit came with aluminum strips and from pictures posted here the other day I guess they are riveted (and glued) to the outer side of the rib on the inside of the capstrip. Then the wingtip is screwed to nutplates mounted on the strips? |
That's what I did, but I think the sexy mount is to use mini aluminum hinge. Rivet one side to the wing and the other to the wing tip and use hinge pin to hold them together. A tab welded to the hinge pin is screwed to the trailing edge. The RV and Lancair guys use this method for cowls all the time and it's really clean. There are no visible fasteners (if you do the rivets right) and there's no scalloping between the fasteners. And yes, amazingly enough they go around fairly tight corners. You couldn't do the leading edge, but you could get close enough. (My forward two fasteners are probably 3" back from the leading edge anyway.)
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 400 hrs. and counting [quote][b]
Deceased K-IV 1200
A glider pilot too. |
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Thu Mar 11, 2010 7:26 am Post subject: Re: help--how to mount wingtips. |
| Quote: | This is what I have guessed but a set of real instructions and pictures would help with rivets/bolt pitches etc.
Dave Goddard |
Dave, the "speedster" wing tip installation is fairly straight forward as you have figured out. It is the builder's option to make them permanent by using rivets and fabric tape over the top or Pk screws and form the fabric under the tip.
I used rivnuts but that is a pain in the butt. If I build another I will use PK screws.
I can't figure out how to attach the instructions. If you want I will email them to you if you send me your address.
Tom
nahsikhs(at)elltel.net
_________________ Tom Jones
Classic IV
Ellensburg, WA |
lcfitt(at)sbcglobal.net Guest
Posted: Thu Mar 11, 2010 8:53 am Post subject: help--how to mount wingtips. |
Dave,
I guess the first thought is if you want the tips removable or not. I chose
to permently attach them as your instructions suggest, but have a smaller
cut out in the tip for inspection purposes and to hide the lights.
I used the aluminum strips as you suggested glued and solid riveted to the
capstrips, top and bottom and then used pop rivets and the Hysol to attach
the tips to the aluminum strip. Sanding corrects the scalloping Guy
mentions, then a bit of filler smooths everything out.
I know there are advantages for removable tips and Guy's suggestion is an
excellent one, Thanks Guy, and would give a clean almost undetectable joint.
The most common method is to use the nut plates and screws. I have found
that the glass thickness at the joint is a bit thinner than the cap strip,
so if you wanted to lay up a layer or two of glass on the inside of the tip,
you could develop enough thickness to countersink the screws if you wanted a
smoother look.
Lowell
Guy Buchanan
Posted: Thu Mar 11, 2010 4:22 pm Post subject: help--how to mount wingtips. |
At 07:54 AM 3/11/2010, you wrote:
| Quote: | I know there are advantages for removable tips and Guy's suggestion
is an excellent one, Thanks Guy, and would give a clean almost
undetectable joint. The most common method is to use the nut plates
and screws. I have found that the glass thickness at the joint is a
bit thinner than the cap strip, so if you wanted to lay up a layer
or two of glass on the inside of the tip, you could develop enough
thickness to countersink the screws if you wanted a smoother look.
I HIGHLY recommend removable tips. It facilitates inspections,
maintenance, and repair enormously. I will eventually modify my tips
using the hinge technique. For now I have countersunk screws into nut
plates which I think looks like crap because of the scalloping
between screws. (Not to mention the screw heads.) You could try inner
and outer carbon strips along the wing tip screw line to cut down the
scalloping, but I don't think you'll eliminate it completely the way
you would with the hinge.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
