Has anyone had static port clog on a Europa?
rparigoris
PostPosted: Tue Mar 09, 2010 3:19 pm    Post subject: Has anyone had static port clog on a Europa? Reply with quote
Has anyone had a static port clog/ice up on a Europa? Did you have an alternative static valve? What are thoughts on installing an alternative valve on a XS I plan to fly VFR?Ron Parigoris [quote][b]
ward.t(at)xtra.co.nz
PostPosted: Tue Mar 09, 2010 4:33 pm    Post subject: Has anyone had static port clog on a Europa? Reply with quote
Ron,
Yes, I have an alternate source under the instrument panel where the static lines enters. Alternate source is the cockpit which I understand is very good, so it is taken off the static main line coming in with a 'tee' and a short tubing to a shutoff valve sticking down from under the instrument panel where you can easily reach it.
Never used it.
Tim
Tim Ward
12 Waiwetu Street'
Fendalton,
Christchurch.
NEW ZEALAND
Ph. 64 3 3515166
Mob 021 0640221
Email ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)
