Adhesive removal was Re: RV-List Digest: 5 Msgs - 03/05/10
chaskuss(at)yahoo.com
PostPosted: Wed Mar 10, 2010 5:56 am    Post subject: Adhesive removal was Re: RV-List Digest: 5 Msgs - 03/05/10 Reply with quote
Ron,
Goo Gone is a citrus based product which will safely remove the adhesive from plastics. You can find it at most quality hardware stores. Home Depot carries it. You will find it in their paint isle, near the spray paints.
FYI, another lister mentioned Goof Off. Be aware that there are 2 varieties of Goof Off. One of the two is mineral solvent based. The solvent based variety WILL damage the plastic, making it cloudy.
Charlie Kuss
--- On Tue, 3/9/10, ronald vandervort <ronvan(at)q.com> wrote:
Subject: Re: RV-List Digest: 5 Msgs - 03/05/10
To: rv-list(at)matronics.com
Date: Tuesday, March 9, 2010, 2:01 PM
My plastic wear strip is cracking and breaking up as well
on my flaps.  When I pull off the pieces a sizable
residue of adhesive is left that needs to be removed.
Has anyone figured out what works to remove that adhesive?
Ron Vandervort RV-6 1470 hrs. always hangared too.
On Mar 6, 2010, at 12:58 AM, RV-List Digest Server wrote:
>    Online Versions of Today's List Digest
Archive
> Today's complete RV-List Digest can also be found in
either of the
> two Web Links listed below.  The .html file
includes the Digest formatted
> in HTML for viewing with a web browser and features
Hyperlinked Indexes
> and Message Navigation.  The .txt file includes
the plain ASCII version
> of the RV-List Digest and can be viewed with a generic
text editor
> such as Notepad or with a web browser.
> HTML Version:
>     http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 10-03-05&Archive=RV
> Text Version:
>     http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 10-03-05&Archive=RV
>    EMail Version of Today's List Digest
Archive
            RV-List Digest
Archive
      Total Messages Posted Fri 03/05/10: 5
> Today's Message Index:
>      1. 11:04 AM - UHMW tape
yellowing  (Frazier, Vincent A)
>      2. 11:35 AM - John Ragozzino
?  (Brian Meyette)
>      3. 12:43 PM - Lycoming vacuum pump
oil seal  (HCRV6(at)comcast.net)
>      4. 01:07 PM - Re: Lycoming vacuum
pump oil seal  (Vanremog(at)aol.com)
>      5. 01:11 PM - Re: Lycoming vacuum
> ________________________________  Message 1
_____________________________________
> Time: 11:04:24 AM PST US
> From: "Frazier, Vincent A" <VFrazier(at)usi.edu>
> Subject: UHMW tape yellowing
> SNIP <<<<<
> The clear UHMW flap tape on my always-hangared ten
year old 6A is
> yellowing and peeling at the edges.  Can this
tape be removed without
> also taking off the aircraft-specific paint?
Sorry, I don't remember
> the brand of paint.
> I pulled it back in a couple of areas and it seemed to
separate fine but
> I would like to hear from someone who "has been there"
before attempting
> to remove it all.
> The present tape came from Vans and I would like to
replace it with
> their reasonably-priced clear UHMW.  Otherwise
I'll go shopping for
> white UHMW.
   >>>>>SNIP
> We carry 4" wide 3M paint protection film that is
perfect for this purpose.  It's
> reasonably priced, removable, and will never
yellow.  $2.45/foot.
> http://www.flyboyaccessories.com/store/index.php?main_page=product_info&cPath=1&products_id=256
> Once again, it's removable up to at least 5 years
later with NO mess.  I use it
> on my Rocket around the fairings, flaps, etc.
And it will NOT yellow. Ever.
> You'll find many uses for it.  Good stuff.
> Vince
> ________________________________  Message 2
> Time: 11:35:26 AM PST US
> From: "Brian Meyette" <bmeyette(at)gmail.com>
> Subject: John Ragozzino ?
> Hey - is John Ragozzino (RV-9 builder) on this
list?   I'd like to ask him a
> couple questions.    Please email me at
> Bmeyette at gmail dot net
> Thanks,
> Brian
> http://www.meyette.us/RV-7Ahome.htm
> ________________________________  Message 3
> Time: 12:43:48 PM PST US
> From: HCRV6(at)comcast.net
> Subject: Lycoming vacuum pump oil seal
> I'm replacing the vacuum pump on my O-360 A1A and
recall that someone posted a
> reminder on the list not long ago that the vacuum pump
oil seal should be replaced
> at the same time. Does anyone have more information on
that, like part number,
> source, and how?
> Harry Crosby
> RV-6 N16CX, 665 hours
> ________________________________  Message 4
> Time: 01:07:08 PM PST US
> From: Vanremog(at)aol.com
> Subject: Re: Lycoming vacuum pump oil seal
> Rocketmeister-
> My catalog shows this part as STD-2217.
> Aviall probably has it.
> Good luck
> -GV
> In a message dated 3/5/2010 12:44:30 P.M. Pacific
Standard Time,
writes:
and recall that someone
> posted a reminder on the list not long  ago that
the vacuum pump oil seal should
> be replaced at the same time.   Does
anyone have more information on that,
> like part number, source, and  how?
> Harry Crosby
> (http://www.matronics.com/Navigator?RV-List)
> (http://www.matronics.com/contribution)
> ________________________________  Message 5
> Time: 01:11:59 PM PST US
> Sac Sky Ranch has the item STD-2217.
> -GV
Standard Time,
writes:
> Harry Crosby
Forum -
FAQ,
   - MATRONICS WEB FORUMS -
List Contribution Web Site -
              -Matt
Dralle, List Admin.
