Voltage gauge question
s.hamer(at)verizon.net
PostPosted: Sat Mar 06, 2010 4:42 pm    Post subject: Voltage gauge question Reply with quote
I have an Electronics International Volts/Amp gauge in my RV-6. It was working fine till I decided to "fix" what I thought was too small of wire through the E-Buss switch circuit. I'm wired per figure Z-11 and the Voltage gauge is powered off of the E-Buss.
Here's what's happening. With the master on, the voltage reads 11.4 (through the diode). When I turn on the E-Buss switch, voltage goes to 12.1. With just the E-Buss on and the master off, voltage reads zero. It didn't do this before I "fixed" it. What have I done?
Steve Hamer
mrspudandcompany(at)veriz
PostPosted: Sat Mar 06, 2010 5:36 pm    Post subject: Voltage gauge question Reply with quote
[b]I have an Electronics International Volts/Amp gauge in my RV-6. It was working fine till I decided to "fix" what I thought was too small of wire through the E-Buss switch circuit. I'm wired per figure Z-11 and the Voltage gauge is powered off of the E-Buss.[/b]
[b]Here's what's happening. With the master on, the voltage reads 11.4 (through the diode). When I turn on the E-Buss switch, voltage goes to 12.1. With just the E-Buss on and the master off, voltage reads zero. It didn't do this before I "fixed" it. What have I done?[/b]
[b]Steve Hamer[/b]
[quote] What did it do before you fixed it? Roger[b]
PostPosted: Sat Mar 06, 2010 9:10 pm    Post subject: Voltage gauge question Reply with quote
Before I fixed it, with the E-Buss on and the master off, the voltage was around 11.7. This seemed too low so I figured the wire in that circuit might be too small so I increased it slightly. That's the only change. If I put my multimeter on the the voltage meter connection with the E-buss only on, it reads 12.3 while the gauge reads 0.
Steve
PostPosted: Sun Mar 07, 2010 5:53 am    Post subject: Re: Voltage gauge question Reply with quote
The vast majority of electrical problems are bad connections, so check those. Pull on wires to make sure they are not broken.
The symptoms point towards a bad voltmeter (or its connections). Connect your hand held meter to the exact same two points that the panel meter is connected to, both hot and ground. If they do not read approximately the same, then one of them is lying.
Joe
Joe Gores
