hurd(at)gvtc.com Guest
Posted: Thu Mar 04, 2010 2:10 am Post subject: Flap Tape Peeling |
The clear UHMW flap tape on my always-hangared ten year old 6A is yellowing and peeling at the edges. Can this tape be removed without also taking off the aircraft-specific paint? Sorry, I don't remember the brand of paint.
I pulled it back in a couple of areas and it seemed to separate fine but I would like to hear from someone who "has been there" before attempting to remove it all.
The present tape came from Vans and I would like to replace it with their reasonably-priced clear UHMW. Otherwise I'll go shopping for white UHMW. TIA
Jim RV6A O360/CS flying 550 hours
kboatright1(at)comcast.ne Guest
Posted: Thu Mar 04, 2010 4:21 am Post subject: Flap Tape Peeling |
I'm in the same situation. I figure I'll try and soften the adhesive with a blow drier and see if I can remove the tape that way. After that, I'll use WD-40 or one of the citrus based cleaners to remove the rest of the adhesive.
But I'd appreciate it if someone else has done this and can offer a proven solution....
Kyle Boatright
2001 RV-6
Neal.George(at)hurlburt.a Guest
Posted: Thu Mar 04, 2010 4:55 am Post subject: Flap Tape Peeling |
Mineral spirits will soften the adhesive without attacking the paint.
remove it all.
TIA
smime.p7s |
5.09 KB |
378 Time(s) |
n621tm(at)tx.rr.com Guest
Posted: Thu Mar 04, 2010 6:02 am Post subject: Flap Tape Peeling |
Jim, I went through this a couple of months ago. My tape didn't last near
that long as yours did. I was able to get the old tape off by heating it
and pulling it up slowly without doing any damage to the paint. I then had
to use something to dissolve some small patches of adhesive that remained
behind. I think I used "Goo Be Gone" without any problems. Tom
yenduc(at)me.com Guest
Posted: Thu Mar 04, 2010 10:01 am Post subject: Flap Tape Peeling |
One thing you might wish to consider:
After you remove the tape from the flap, you might consider putting
the tape on the lower surface of the wing where it rubs on the flap.
That way the tape is out of sight and still protects the flap. One
point though you must keep the flap surface clean so it will not get
scraped by bugs or grit.
dave
RV 7A
145 hours
On Mar 4, 2010, at 4:53 AM, George, Neal E Capt USAF ACC 505 TRS/DOJ
wrote:
| Quote: | Mineral spirits will soften the adhesive without attacking the paint.
yellowing
taking off
paint.
but I
attempting to
remove it all.
their
UHMW.
TIA
Vanremog(at)aol.com Guest
Posted: Thu Mar 04, 2010 10:14 am Post subject: Flap Tape Peeling |
Hit it lightly with a heat gun just ahead of the area you are peeling off and it should come off much easier. Clean the area with mineral spirits or Coleman Lantern Fluid (Naphtha) and reapply new tape. All of the natural UHMW is milky (translucent) white. There are some other protective tapes that could be used that are more transparent. Check out 3M website.
-GV
In a message dated 3/4/2010 10:04:32 A.M. Pacific Standard Time, yenduc(at)me.com writes:
[quote]I pulled it back in a couple of areas and it seemed to separate fine
| Quote: | but I
attempting to
remove it all.
their
UHMW. |
