Electronic Ignition Choice
robin1(at)mrmoisture.com
PostPosted: Wed Mar 03, 2010 5:56 pm    Post subject: Electronic Ignition Choice Reply with quote
I am interested in using 1 Mag and 1 electronic ignition system on my
8A. Does anyone have an opinion on what would be the preferred system
for my second ignition the P-Mag or the Hall Effect Light Speed Plasma
III.
Robin
Neal.George(at)hurlburt.a
PostPosted: Thu Mar 04, 2010 4:43 am    Post subject: Electronic Ignition Choice Reply with quote
Robin -
I'd recommend a P-Mag. Smaller, self-contained, self-powered, easy set-up
and excellent support.
neal
III.
Robin
smime.p7s
 Filename:  smime.p7s
 Filesize:  5.09 KB
 Downloaded:  503 Time(s)
riffelj
PostPosted: Thu Mar 04, 2010 7:46 am    Post subject: Electronic Ignition Choice Reply with quote
Robin,
I chose putting 2 P-Mags on my RV-7A and couldn't be happier with the choice. The things I considered when I compared ignitions were:
  • How durable/reliable are they?
    • I knew I didn't want Mags because I'd lived with them on previous planes. They weren't Bad, but they took some care and maintenance.
    • There was a lot of chatter about the early E/PMags. But they've been reliable for me and the chatter has quieted down the last couple years. As I understand it, they only have one moving part (a shaft in a bearing) that wears a LONG time.
  • How easy is it to mount (orientation and form-factor)?
    • The PMags have roughly the same size/shape as Mags and can be mounted in any orientation.
  • What about fail-safety?
    • I chose two PMags so I didn't need any other power source if I had an alternator failure and battery failure. The down side is that I can not hand-prop it if I have a completely dead battery (but I'm not thrilled about hand-prop'g anyway). So I put a jump start connection under the cowl (highly recommended ... ask me how I know)[img]cid:330(at)goomoji.gmail[/img]
  • How easy is it to time?
    • The PMags couldn't be easier ... less than 1 minute for BOTH units and no special equipment! A REAL advantage if you've timed mags before!
  • What about spark plugs?
    • With electronic ignition on both sides, I could use auto sparkplugs (at) $2-3/ea vs aviation plugs (at) $20+. That is quite a savings. No fouling either.
  • Tach signal
    • Yup, works great w/ my GrandRapids EIS.
  • Miscellaneous
    • I talked w/ the EMag folks at OSH, liked them, felt I could trust them and they seemed like they'd be in business into the future ... other vendors, not the same.
  • Support
    • I've had their service bulletin done (There's been only one on mine) and they were quick and fair. They've been Terrific whenever I've called with questions.
  • Down sides
    • Can't really think of any. The connector is a little strange but has been reliable and seems robust so far. I can not vary the timing from the cockpit - but haven't really wanted/needed to.
I only have experience with PMags and Mags (on previous planes), so I can't compare other systems.
Good luck.
"Jerry" Riffel
N554JR - 125hrs
 Filesize:  96 Bytes
 Viewed:  4250 Time(s)
rv8builder
PostPosted: Thu Mar 04, 2010 8:36 am    Post subject: Electronic Ignition Choice Reply with quote
If you do go with the P-Mag, check out this E or P Mag monitoring
device marketed by a friend of mine, Bill Repucci, who is flying a
RV-9 out of NC.
His web site is http://www.eicommander.com/
Dale
On Wed, Mar 3, 2010 at 7:20 PM, Robin Marks <robin1(at)mrmoisture.com> wrote:
III.
Robin
Dale
