Controlling Rotax 912 oil temp
lgold(at)quantum-associat
PostPosted: Mon Mar 01, 2010 6:48 pm    Post subject: Controlling Rotax 912 oil temp Reply with quote
It was taking a long time to warm my 912 oil temps on cold days and the temps were staying below the recommended levels. I was going to put in an oil radiator bypass thermostat, but after purchasing the unit I realized it required putting in a lot of extra pluming, thus increasing the chances of a failure. Instead, I built a simple shutter to reduce airflow through the radiator (see pics below). The oil changes temperature almost immediately when opening or closing this shutter. There is a 20-degree difference within a minute or so.
I have the old style engine mount and this shutter may not fit with the new mount.
Les
 Filesize:  17.73 KB
 Viewed:  7303 Time(s)
 Filesize:  18.34 KB
bobkat
PostPosted: Mon Mar 01, 2010 6:57 pm    Post subject: Controlling Rotax 912 oil temp Reply with quote
Great idea Les! I have been playing around with a vane type of arrangement but yours looks better. Thank you! Right now I've been using Mexican chrome (duct tape) up here in cold ND, but with days getting warmer a cockpit adjustable thing is better. Same reason why I didn't put on the thermostat.
 Filesize:  17.73 KB
 Filesize:  18.34 KB
vgstol(at)bigpond.net.au
PostPosted: Mon Mar 01, 2010 7:24 pm    Post subject: Controlling Rotax 912 oil temp Reply with quote
I tried both the Permacool and Thermostasis oil thermostats, with no appreciable results from either......  Certainly not worth all the extra hoses and hose clamps holding in hot oil.....  A shutter like yours looks like the way to go. JG
On Tue, Mar 2, 2010 at 12:39 PM, Les Goldner <lgold(at)quantum-associates.com (lgold(at)quantum-associates.com)> wrote:
Les
jpspencer(at)cableone.net
PostPosted: Tue Mar 02, 2010 10:36 am    Post subject: Controlling Rotax 912 oil temp Reply with quote
Les
Understand the shutter works well for warmup...can you precisely control the temp in flight? I built a vane type shutter and couldn't get it to work as designed. I'm tired of fooling around with tape and having to land enroute to adjust it as temps warmup...
Joe
PostPosted: Tue Mar 02, 2010 4:02 pm    Post subject: Controlling Rotax 912 oil temp Reply with quote
I can hold the shutter anywhere from right against the oil heater (0-degree) to about 75-degrees away. In flight the only testing I did was at the two extremes, 0 and 75-dregrees, and noticed that the oil temps changed about 20-degrees F on a 50F day.
From: owner-zenith701801-list-server(at)matronics.com [mailto:owner-zenith701801-list-server(at)matronics.com] On Behalf Of Joe Spencer
Sent: Tuesday, March 02, 2010 10:36 AM
To: Zenith701801-List(at)matronics.com
Subject: Re: Controlling Rotax 912 oil temp
Les
Joe
agibeaut
PostPosted: Tue Mar 02, 2010 4:19 pm    Post subject: Controlling Rotax 912 oil temp Reply with quote
Les, could you forward the pics of the oil cooler baffle to me? I could not open them.
--- On Tue, 3/2/10, Les Goldner <lgold(at)quantum-associates.com> wrote:
From: Les Goldner <lgold(at)quantum-associates.com>
Subject: RE: Re: Controlling Rotax 912 oil temp
Date: Tuesday, March 2, 2010, 4:56 PM
I
only testing I did
that the oil temps
Behalf Of Joe
Spencer
912 oil temp
Les
Understand
control the temp in
as temps warmup...
Joe
   http://www.matronics.com/Navigator?Zenith701801-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution
