Electric Trim Problems
John Price
PostPosted: Mon Mar 01, 2010 12:59 am    Post subject: Electric Trim Problems Reply with quote
Any help on this one would be gratefully received.
Classic Monowheel G-SHSH now flying for over 6 years.
We have now an intermittent fault on the electric trim.
The controller is by a 'coolie hat' on the stick driving a Ray Allen servo.
The trim will always work nose up but has an intermittent fault when used to trim nose down.
We have replaced the switch and the servo but still the problem remains.
Any thoughts ?
John Price.
ptag.dev(at)tiscali.co.uk
PostPosted: Mon Mar 01, 2010 2:05 am    Post subject: Electric Trim Problems Reply with quote
Hi! John.
Yes I can tell you all about it and most who fly with me can also!
I had this problem initially a number of years ago and the Ray Allen people
assured me it must be a wiring failure, the hassle proving all the circuitry
needs to be done to be believed. Still the failure was intermittently
present. Next I had to remove the servo (fortunately I had built in a
facility which locked the servo locating bolt heads enabling the nuts to be
removed from the rear...in anticipation of needing it out!) I returned it to
Ray Allen Company where they failed to reproduce the symptoms. In my case
the failure was identical to yours and I found much to my horror that if I
let go of the control stick and trimmed fully nose up (scary because you
wouldn't land it like that and the forces on the stabilators and rear
controls are phenomenal)it then will be possible to reverse the trim motor.
They returned the servo after checking and for good measure included a
replacement MK1 relay for 50% of the normal price.
I refitted the servo and also replaced the relay. The problem had been
cured.
Some considerable time ensued before the identical problem returned.
I have reported this to the Ray Allen and they said they had now identified
that the MK1 Relay actually fails but in one direction only so when the
system is reversed it hides the fault.
They have now (again at 50% cost) have sent a MK2 relay saying that they
have at last identified the original fault. The MK2 is slightly different in
shape and size and sitting on my desk awaiting fitting.
Pleased to be of service to you with this news...(as usual I am out in front
where trouble is concerned !)
However I now am most concerned that you aren't preceding me with the MK2
which is failed? If you would advise me that I'd be obliged.
My system has a panel trim switch and a control stick top trim switch too.
Bob Harrison G-PTAG Rotax 914.
kevann(at)gotsky.com
PostPosted: Mon Mar 01, 2010 6:00 am    Post subject: Electric Trim Problems Reply with quote
John,
In the wires from the servo in the tail going forward you should have a
splice or connector. Have you checked that?
Kevin
gavanne(at)iconz.co.nz
PostPosted: Mon Mar 01, 2010 3:59 pm    Post subject: Electric Trim Problems Reply with quote
Hi Bob and John
This is very coincidental, I am just in the process of fitting a new RS2
rocker switch on the panel because of a sticking trim. As you say it sticks
when trimming down and I have to reverse the direction to rectify the
situation. I had a spare rocker switch from some time ago when I had a trim
runaway and bought a new switch but it never recurred so didn't fit it.
I also run the system with a stick top grip through a RayAllen relay deck,
probably the mark one which I have had for some time
What you are saying is that the Relay is the problem.
I'll email RayAllen and see what they say
Gavin Lee....... ZK-EPA #355
terrys(at)cisco.com
PostPosted: Mon Mar 01, 2010 4:13 pm    Post subject: Electric Trim Problems Reply with quote
We have been having problems with sticking trim, both directions, but
only from the rocker switch in the instrument panel. The trim buttons
on our pilot's stick never seem to have that problem. Since both sets
of switches are connected to the same circuit at the relay deck, It
seems that it would have to be a bad switch, not the relay deck. Only
if sticking were from both switch positions would I expect it to be a
relay deck problem.
Any comments would be appreciated, since I am just about to replace the
panel mounted rocker switch.
Terry Seaver
A135
PostPosted: Mon Mar 01, 2010 5:19 pm    Post subject: Electric Trim Problems Reply with quote
I do have the same problem from the stick mounted switch as well, as I
mentioned I am changing the rocker switch because I had a spare and also as
the start of a process of elimination, just had a response from Ray
Allen.....
Hello,
Sorry to hear of your trim system problems. When a servo trims one way and
not the other, I would suspect a relay problem.
Our REL-2 have much more durable relays inside. It's a little bit larger,
but has the same functionality and wire colors.
You can download our order form and FAX/email it to us. Aircraft Spruce has
our REL-2 available also.
Best regards,
Scott Menziimer
Doesn't say anything about a half price relay but I will probably order one
anyway
Gavin Lee.....#355
paul.the.aviator(at)gmail
PostPosted: Mon Mar 01, 2010 6:56 pm    Post subject: Electric Trim Problems Reply with quote
Hi All,
I had this problem and I ended up replacing the Ray Allen stuff with one of Matt Drallel's trim controllers. Matt's unit can also be set to slow down the servo speed.
Paul
gholland(at)content-strea
PostPosted: Mon Mar 01, 2010 9:18 pm    Post subject: Electric Trim Problems Reply with quote
I chose the same Unit as Paul, the Matt Dralle Speed Governor for my Europa.
It can be found at: http://www.matronics.com/governor/index.htm and at $67 is excellent value.
If positioned correctly is easy too get to and adjust during the initial flights of Europa to get a smoother TRIM transition rather than the high speed operation that seems the normal.
Gerry
Gerry Holland
07808 402404
[url=gholland(at)content-stream.co.uk]gholland(at)content-stream.co.uk[/url]
Based at White Ox Mead, Near Bath, UK
[img]cid:3350351603_15561714[/img]
 Filesize:  20.27 KB
 Viewed:  18672 Time(s)
PostPosted: Tue Mar 02, 2010 1:56 am    Post subject: Electric Trim Problems Reply with quote
Hi! Terry.
The relay sticks in the up mode and will not reverse until full travel
position then reverses and hides the fault Which ever switch you use.. Take
Scott Menzemer's advice and get a MK2 relay.
Bob Harrison G-PTAG
mikenjulie.parkin(at)btin
PostPosted: Tue Mar 02, 2010 2:56 am    Post subject: Electric Trim Problems Reply with quote
Hi Guys,
I note that these relay decks cost $46.00 and they are even more to buy
outside the USA. I have roll and pitch trim servos operating the trim
through a home made relay deck. I recently modified the relay deck to
facilitate the auto-trim feature of my altitude hold. I have never had any
problems at all ( touch wood). The basic pitch trim only requires 2 relays
and 2 diodes and a bit of veroboard (all available from Maplins) - total
cost about £5.00. Making a relay deck really is a simple task - takes about
an hour.
Mike
Best regards,
Scott Menziimer
anyway
Ivor Phillips
PostPosted: Tue Mar 02, 2010 6:46 am    Post subject: Electric Trim Problems Reply with quote
I would second that, Its never been a problem so far Smile
Ivor
is excellent value.
Gerry
Gerry Holland
07808 402404
John Price
PostPosted: Tue Mar 02, 2010 11:08 am    Post subject: Re: Electric Trim Problems Reply with quote
Thanks Chaps,
Having given this some thought I think that we will replace the relay for a new Mk 2 Ray Allen unit. This Saturdays job!
We don't think that the wiring is the fault because the DC motor would exhibit the problem when driving in either direction.
As we didn't build the aeroplane any suggestions where we might find the thing? I suspect behind the panel close to the isolator switch might be a good starting point. Last help, Is taking the panel off easy, or a sod of a job ?
John.
PostPosted: Tue Mar 02, 2010 12:12 pm    Post subject: Electric Trim Problems Reply with quote
John Hi!
Been following and commenting on your TRIM problem and now commiserate with
you having to battle with an unknown Panel.
As a Builder and until recently an operator of a Europa XS can I suggest
some ideas.
Firstly...can you contact the Builder or are there any documents with the
Aircraft.
If itıs a Œrealı Relay you might hear it click so create a quiet atmosphere
and get your ear to the panel.
If you have to go into the Panel make the first expedition based around
removing single items such as Instruments or Radio.
If the ultimate is required....the bloody thing needing to come out then
remove Control sticks and bias towards rear of cabin. Cover the ŒTunnelı to
avoid damage and remove any vertical levers or switches in that area too.
If you are lucky it will be secured by nuts on the Firewall side. BTW it
will be heavy so watch your back, fingers etc. Could be 25lbs. Itıs not
impossible to cut small sub panels with Modellers Jigsaw to gain access and
repair or make good afterwards.
Best of luck! It will all work out if you take your time, and move Panel out
slowly with someone watching down through Front Windshield to feedback what
they can see being stretched!
Gerry
Gerry Holland
07808 402404
PostPosted: Tue Mar 02, 2010 1:02 pm    Post subject: Electric Trim Problems Reply with quote
Hi! John,
There wasn't a recognized way to fix the panel, You will probably have to
locate all the connection plugs as you pull the panel forward. Disconnect
the battery though ...first operation.
I built mine as fixed and put two access panels from the engine side of the
firewall, but it's still a pig of a job.
I would think it will be located some where close by the Flap relay as a
pair.(Be sure to get the right one !
Bob Harrison G-PTAG
PostPosted: Tue Mar 02, 2010 3:57 pm    Post subject: Electric Trim Problems Reply with quote
job ?
John.
John,
Take care before ripping into the instrument panel. If the installation has
a single rocker switch for the pitch trim, it is quite possible that there
is not a relay deck fitted. A relay deck is not required in the basic
system. It depends on the rating of the switch contacts, the contacts of
the supplied rocker switch were up to the task.
If your 'coolie hat' stick top is a Ray Allen one, in the basic
configuration, it does not require a relay deck.
If you can contact the original builder, tips on panel removal would be very
useful. I know of some installations that were not designed to be
removable.
Mike.
PostPosted: Tue Mar 02, 2010 9:35 pm    Post subject: Electric Trim Problems Reply with quote
Hi John
If you have a stick top switch and a rocker switch there will be a relay
deck in the system
Both switches will be connected into the relay and 2 wires will run from the
relay to the servo. The relay is probably fairly close behind your rocker
switch
Ray Allen has an excellent wiring diagram on their web site for this exact
situation.
Good Luck
Gavin Lee....#355
topglock(at)cox.net
PostPosted: Wed Mar 03, 2010 7:03 am    Post subject: Electric Trim Problems Reply with quote
Though handy, a relay is not necessary in a two switch situation. My
bird is rigged with grip top buttons at P-1 and a rocker at P-2. The
difference is that I have them tied into a diverter switch. Switch is
in one position when P-1 is in control and in the other position when
P-2 has the A/C. Switch is just above the rocker switch, so P-2 has no
trouble switching the system. A lot cheaper than the relay, and less
troublesome...
Jeff - Baby Blue
On 3/2/2010 9:56 PM, Gavin & Anne wrote:
Hi John
deck in the system
switch
situation.
Good Luck
Gavin Lee....#355
