Posted: Mon Mar 01, 2010 8:57 am Post subject: Setting flap position |
John, Kolb guys,
So I assume you suggest just setting the flaps to be in line with the underside of the wings, straight from wing leading edge to flap trailing edge?
Thanks, Mike Welch
Your E-mail and Mor/GBL/go/201469229/direct/01/' target='_new'>Sign up now. [quote][b]
Posted: Mon Mar 01, 2010 9:39 am Post subject: Setting flap position |
I adjust my flaps about even with the ailerons and the bottom of the wing. During test flights I can see where the flaps and ailerons are flying, then adjust to suit my tastes.
john hauck
[quote] So I assume you suggest just setting the flaps to be in line with the underside of the wings, straight from wing leading edge to flap trailing edge?
Thanks, Mike Welch
_________________ John Hauck
Titus, Alabama |
