msm_9949(at)yahoo.com Guest
Posted: Mon Feb 22, 2010 10:22 am Post subject: C-Box w/clutch. WAS 582 Start Up Procedure |
James,
I haven't had the occasion to need to manually advance the engine for inspection or otherwise. I just "bump" the starter. The clutch does make it start easier and "idle" much smoother although I've had problems rejetting and adjusting the idle low enough (below 2500 rpm) to keep the prop from engaging. As soon as it's warmed up, it idles at about 2500 and the prop spins away. I've learned to live with it.
My main concern is the engine out situation, drag and drastically increased sink-rate that I expect will result from a free-wheeling prop. One of these days I'll climb to about 5000 agl (over the field), cut power and discover exactly what happens. Alot of people have speculated on this but I don't think we have any real data on it yet.
Marco Menezes N99KX
Model 2 582-90 C-Box 3:1 w/clutch
Hersey, MI
--- On Mon, 2/22/10, WurlyBird <james.t.trizzino(at)us.army.mil> wrote:
Subject: Re: 582 Start Up Procedure
Date: Monday, February 22, 2010, 11:34 AM
--> Kitfox-List message posted by: "WurlyBird" <james.t.trizzino(at)us.army.mil (james.t.trizzino(at)us.army.mil)>
Marco, I see you are using a clutch on the 582. I thought about this since it is supposed to make low RPM idle very nice but I decided against it since I would have no way to manually advance the engine for checking the cylinders, hand propping, etc. Have you found this to be an issue or does it not affect your flying?
James
Kitfox 3 / 582 / GSC prop
The ink is still drying on my new certificate
http://forums.matronics.com/viewtopic.php?p=287645#28764om/Navigator?Kitfox-List" target=_blank>http://www.matronics.com/Navigatosp; - MATRONICS WEB FO/" ; -Matt Dralle, List Admin==========
akflyer
Posted: Tue Feb 23, 2010 3:22 pm Post subject: Re: C-Box w/clutch. WAS 582 Start Up Procedure |
I can give you real info on the free wheeling prop.. cuts the glide ratio to that of an anvil. The easier cold starts, warm up and idle make it worth the trade off to me.
I can turn the idle down on mine till she dies. Stock jetting rotax calls for. I have mine set to idle at 1600- 1650 and she is smooth smooth.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
