How do you reliably attach wire to a solder lug swit
rparigoris
PostPosted: Sun Feb 28, 2010 9:32 am    Post subject: How do you reliably attach wire to a solder lug swit Reply with quote
Hi Bob
Thx. for the reply."What can I do besides double heat shrinking lugs and wires to decrease chance of a mechanical fatigue failure?""> Single 1" pieces of heat shrink should be fine. > We've never double-covered any similar joint in > a TC aircraft that I'm aware of. What part number > of switch are you using?"I am using from Newark C & K - T201SHCQE - Toggle Switch.Ron Parigoris [quote][b]
