dwntzl(at)yahoo.com Guest
Posted: Fri Feb 26, 2010 8:03 am Post subject: Aymar DeMuth Propellers |
Hello,
Does anyone have any info on the above?? Phone is disconnected, e mail no longer goes through. Mike was such a dedicated propeller guy I can't believe he just gave it up.
DW RV6 460 enjoyable hrs behind an Aymer DeMuth prop
--- On Fri, 2/26/10, RV-List Digest Server <rv-list(at)matronics.com> wrote:
From: RV-List Digest Server <rv-list(at)matronics.com>
Subject: RV-List Digest: 3 Msgs - 02/25/10
To: "RV-List Digest List" <rv-list-digest(at)matronics.com>
Date: Friday, February 26, 2010, 2:59 AM
Today's complete RV-List Digest can also be found in either of the
of the RV-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2010-02-25&Archive=RV
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2010-02-25&Archive=RV
RV-List Digest Archive
Total Messages Posted Thu 02/25/10: 3
Today's Message Index:
1. 09:26 AM - Re: Adding Thinned Resin to inside of cowling (Bob J.)
2. 03:52 PM - X-plane flight simulator (thomas sargent)
3. 06:58 PM - Re: X-plane flight simulator (Dave Nellis)
________________________________ Message 1 _____________________________________
Time: 09:26:28 AM PST US
Subject: Re: Adding Thinned Resin to inside of cowling
From: "Bob J." <rocketbob(at)gmail.com (rocketbob(at)gmail.com)>
I've had good luck with putting the resin in the microwave for a few
seconds, then mixing it. It will set up a little more quickly but its water
thin if you do this. For large layups I do this every time since I go thru
the epoxy quickly, and it makes the fabric wet out much better.
Bob Japundza
RV-6 flying F1 under const
On Wed, Feb 24, 2010 at 10:18 AM, Ian <ixb(at)videotron.ca (ixb(at)videotron.ca)> wrote:
| Quote: | Just a suggestion on an alternative solvent, when I tried this on RTV,
methyl ethyl ketone (MEK) was much better than acetone.
Acetone had the same effect of turning the RTV to gum, whereas the MEK
resulted in a nicely runny mixture. It evaporates and produces the desired
end result in RTV. It might be worthwhile trying this with epoxy.
Side note for folks outside the US. MEK is available in Canada only, it
seems, in lacquer thinner. Apparently it can be used to make crystal meth
or some such, so it's not readily available.
Ian Brown, Bromont, Quebec RV-9A
________________________________ Message 2 _____________________________________
Time: 03:52:04 PM PST US
Subject: X-plane flight simulator
From: thomas sargent <sarg314(at)gmail.com (sarg314(at)gmail.com)>
Has any one used the X-plane simulator program? It claims to feature RV's
among many other planes (as well as roll-your-own). Any opinions would be
useful. It's interesting to me because it runs on Linux.
Tom Sargent
________________________________ Message 3 _____________________________________
Time: 06:58:42 PM PST US
From: Dave Nellis <truflite(at)yahoo.com (truflite(at)yahoo.com)>
Subject: Re: X-plane flight simulator
I have been a user of X-plane for many years. I am running V8 at the moment because
I cannot handle V9 on my puter. If you want to fully simulate a flight
from engine start up through taxiing, take off and landing, it is quite possible.
You select your radio frequencies, weather conditions ( I am a VFR pilot
and I fly IFR minimums a lot), aircraft type, the works. Fly with an engine out
and still get to an airport safely.
www.x-plane.org is the best place to get any type of aircraft imaginable.
You can design your own aircraft.
It is a great modern day "Links Trainer".
I flew a 747 out of a 4000 foot field and didn't wreck the aircraft and then landed
it in a 30knot crosswind after dodging convective weather enroute.
In summary, you will enjoy it and you can't go wrong with this program.
Dave Nellis
--- On Thu, 2/25/10, thomas sargent <sarg314(at)gmail.com (sarg314(at)gmail.com)> wrote:
| Quote: | From: thomas sargent <sarg314(at)gmail.com (sarg314(at)gmail.com)>
Subject: RV-List: X-plane flight simulator
To: "rv-list" <rv-list(at)matronics.com (rv-list(at)matronics.com)>
Date: Thursday, February 25, 2010, 5:19 PM
program? It claims to feature RV's among many other
Linux.
Tom Sargent
//www.matronics.com/Navigator?RV-List" target=_blank>http://www.matronics========================
kboatright1(at)comcast.ne Guest
Posted: Fri Feb 26, 2010 8:49 am Post subject: Aymar DeMuth Propellers |
They are in SC now and are in business. When I get home this evening I will post current contact info.
On Feb 26, 2010, at 10:50 AM, d wntzl <dwntzl(at)yahoo.com (dwntzl(at)yahoo.com)> wrote:
[quote]Hello,
--- On Fri, 2/26/10, RV-List Digest Server <rv-list(at)matronics.com (rv-list(at)matronics.com)> wrote:
From: RV-List Digest Server <rv-list(at)matronics.com (rv-list(at)matronics.com)>
To: "RV-List Digest List" <rv-list-digest(at)matronics.com (rv-list-digest(at)matronics.com)>
HTML Version:
Text Version:
From: "Bob J." <[url=mailto:rocketbob(at)gmail.com]rocketbob(at)gmail.com (rocketbob(at)gmail.com)[/url]>
Bob Japundza
On Wed, Feb 24, 2010 at 10:18 AM, Ian <[url=mailto:ixb(at)videotron.ca]ixb(at)videotron.ca (ixb(at)videotron.ca)[/url]> wrote:
From: thomas sargent <[url=mailto:sarg314(at)gmail.com]sarg314(at)gmail.com (sarg314(at)gmail.com)[/url]>
Tom Sargent
From: Dave Nellis <[url=mailto:truflite(at)yahoo.com]truflite(at)yahoo.com (truflite(at)yahoo.com)[/url]>
Dave Nellis
--- On Thu, 2/25/10, thomas sargent <[url=mailto:sarg314(at)gmail.com]sarg314(at)gmail.com (sarg314(at)gmail.com)[/url]> wrote:
| Quote: | From: thomas sargent <[url=mailto:sarg314(at)gmail.com]sarg314(at)gmail.com (sarg314(at)gmail.com)[/url]>
To: "rv-list" <[url=mailto:rv-list(at)matronics.com]rv-list(at)matronics.com (rv-list(at)matronics.com)[/url]>
Linux.
Tom Sargent
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
Posted: Fri Feb 26, 2010 10:46 am Post subject: Aymar DeMuth Propellers |
Update... I just spoke with Mike Demuth, who was in the shop making propellers.
His number is 803-321-0569.
[quote]Hello,
HTML Version:
Text Version:
Bob Japundza
Tom Sargent
Dave Nellis
Linux.
Tom Sargent
