jeanphilippeneel(at)yahoo Guest
Posted: Thu Feb 25, 2010 5:49 am Post subject: ECU for NSI propeller |
Bonjour à tous,
I have been very happy with my CAP NSI propeller during 1100h used with a simple hand operated changing pitch system. Unfortunatelly , the Electronic Control Unit has just failed:
The way to the fine position woks fine , as well as red light and beeper at the course end .
The way to coarse position is in flaw . I tested motor hub from the brush hoder separatly from ECU : mecanism works well
Then tested the ECU out put voltage ( brush holder not connected) and verified 12v on one way and -12v on the other . During that test I heared closing noise of the 3 electromecanical relays.
So separatly two parts of the global system work well
When every thing is reconnected , the only way working is to fine position.
I suppose the electronic card is defective. Having no electrical drawing of that card I cannot invastigate more away
Is there some body from the Europa community having had such a problem or more simply ideas to help me?
Thank you
Jean-Philippe Neel
Europa N° 273 F-PSLH
Grenoble
France
simonlongstaff(at)blueyon Guest
Posted: Fri Feb 26, 2010 8:51 am Post subject: ECU for NSI propeller |
It may be that the blades are "sticking" when moving in the coarse
direction. More current is taken and the ECM "recognises" this a pitch
stop so giving the red light and sound warning. I've had this a few
times and is resolved by dismantling the hub, cleaning and regreasing.
If you need any CAP 140 bits, Maxwell Propulsion took over NSI's
stock: http://www.maxwellpropulsion.com/, look under inventory
reduction sale.
If you need a copy of the CAP 140 manual let me know and I'll send you
a photocopy.
Cheers
Simon Longstaff
gcrowder2
Joined: 09 Jan 2006 Posts: 136 Location: Golden, Colorado USA
Posted: Fri Feb 26, 2010 10:03 am Post subject: ECU for NSI propeller |
Hey Jean-Philippe - I have a spare NSI CAP140 ecu controller I have'nt used for years.
It was working fine when I removed it. If you can't resolve the issue I could send it to you for just shipping charges from the USA.
Glenn
Date: Thu, 25 Feb 2010 13:48:03 +0000
Subject: ECU for NSI propeller
.ExternalClass DIV {;} Bonjour à tous,
Thank you
Jean-Philippe Neel
Grenoble
France
| Quote: | http://www.matronics.com/Navigator?Europa-List
ronics.com
ww.matronics.com/contribution
| Your E-mail and More On-the-Go. Ge29/direct/01/' target='_new'>Sign up now.
42.85 KB |
4372 Time(s) |
