Z-12 Architecture - Parallel Master Contactors
rckol
PostPosted: Fri Feb 26, 2010 8:23 pm    Post subject: Z-12 Architecture - Parallel Master Contactors Reply with quote
In "A Short Discussion of the Endurance Bus" on page Z-2 of Rev 12A of The AeroElectric Connection it states that "Unless you're planning TWO alternators (Z-12, Z-13 or Z-14) then the purpose of the e-bus is to provide a minimum consumption mode of operation in a battery only condition..."
Z-14 has no ebus
In Z-13, the ebus is tied to the output of the 8 AMP alternator and it functions to limit the load on the alternator (as plan B) but also provides for a battery only mode (Plan C) in the event of an unlikely simultaneous failure of both alternator systems.
In Z-12, it seems the function of the e-bus is a battery only mode of operation for either either of the following:
a. A Plan B in the event that an open master contactor failure renders both alternators unusable or
b. A Plan C in the event of an unlikely failure of both alternator systems for other reasons on the same tank of fuel.
For Z-12, if instead of an e-bus, a parallel master contactor was provided:
a. Plan B in the case of an open master contactor would be to close the parallel contactor resulting in a fully functioning alternator(s) and
b. Plan C would be unchanged.
The cost and complexity of an extra contactor compared to an e-bus would seem to be about a wash.
What would be the downside other than the need to thoughtfully manage the electrical loads in Plan C?
rck
PostPosted: Sat Feb 27, 2010 8:55 am    Post subject: Re: Z-12 Architecture - Parallel Master Contactors Reply with quote
Re: A second parallel battery contactor in lieu of an E-Bus.
The cost of the E-Bus and diode and switch and relay are relatively inexpensive and weigh less than a second contactor and associated heavy wire. When I am faced with a decision, I ask myself, "What is best in the long run?"
Your proposal is feasible for a backup in case of contactor failure in Z-12 (two alternators). I do not see any safety issues. You have double the chance of leaving the master switch on. Smile
Joe
Joe Gores
