How did you set these rivets
william(at)gbta.net
PostPosted: Wed Feb 24, 2010 10:04 am    Post subject: How did you set these rivets Reply with quote
These are on the top wing skin (section 16). Riveting the skin to the rear spar flange on the inboard edge (where the rear spar reinforcement fork and doubler plate are). As you can see, mine turned out less than stellar. I'll drill them out and try again but thought I'd see if anybody has any secrets. There isn't much room between the tail of the rivet and the doubler plate to get a bucking bar on it square and I don't have a squeezer head deep enough to reach over the skin edge.
Thanks in advance
Bill
 Filesize:  191.66 KB
 Viewed:  7824 Time(s)
tsts4
PostPosted: Wed Feb 24, 2010 10:21 am    Post subject: Re: How did you set these rivets Reply with quote
Bill,
What shape is your bucking bar? There's no problem with resting the bar on the heads of the 470s in order to keep it square. It also might help to use a partner so that the bucker can focus 100% on keeping the bar square to the rivet.
While you're at it you might want to check your pressure as all of those rivets look over-driven. 35-38psi is all you need for a 3-3 to 3-5 rivet. Also try shortening your shooting duration to say just over a second, stop and see how the rivet's setting. Better to under set and hit it again with a quick blurp then to blast away. Don't worry about work hardening these small rivets.
Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying
Phil.Perry(at)netapp.com
PostPosted: Wed Feb 24, 2010 10:47 am    Post subject: How did you set these rivets Reply with quote
Disclaimer - I haven't built my wings....
But you might be able to drill out the interfering rivets, then reset
them after the other one's are bucked??
Phil
AV8ORJWC
PostPosted: Wed Feb 24, 2010 11:05 am    Post subject: How did you set these rivets Reply with quote
3M prop tape (Impact Tape) or in a pinch cheap electrician tape placed on the side of the bucking bar which is resting on the 470 heads should work nicely.
I would redrill and reset the toenailed bucked heads as you recommend. Often, it is the bucking bar skipping off the rivet that causes the imperfection shown in your picture. Use of a 2X instead of a 3X gun or lower line pressure can help the outcome. Having a teaser trigger helps with the rhythm as well.
Paul Grimstad #40450, found a 0.0625" foam with adhesive used by journeyman electricians inside junction boxes which is the cat's meow. He had a bigger sheet of it and it had little tabs which could be placed on several sides of a bucking bar. The foam also damned some of the vibration into the assistant's hand. Prop tape last a little longer. Electricians tape has poor quality adhesive but they all provide a cushion on those 470 heads.
John Cox
#40600
From: owner-rv10-list-server(at)matronics.com on behalf of Bill and Tami Britton
Sent: Wed 2/24/2010 8:07 AM
Subject: How did you set these rivets
Thanks in advance
Bill
jeff(at)westcottpress.com
you can also run a piece of wide masking tape over the heads of the
470's up to the corner to keep the bucking bar that's resting on them
from mucking anything up.
Jeff Carpenter
40304
on the cusp of final install of the cabin top
On Feb 24, 2010, at 10:21 AM, tsts4 wrote:
Bill,
Todd Stovall
728TT (reserved)
RV-10 Empacone, Wings
http://forums.matronics.com/viewtopic.php?p=287987#287987
Sstella(at)incisaledge.co
PostPosted: Wed Feb 24, 2010 11:23 am    Post subject: How did you set these rivets Reply with quote
I just laid the square shaped bucking bar on the 470’s and that kept it square to the rivet and the duct tape on the bucking bar protected the rivets.
Steve Stella
#40654 Wings
N521RV reserved
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill and Tami Britton
Sent: Wednesday, February 24, 2010 11:08 AM
Thanks in advance
Bill
william(at)gbta.net
PostPosted: Wed Feb 24, 2010 3:54 pm    Post subject: How did you set these rivets Reply with quote
I guess I didn't get my point across in the original e-mail. The 470's
aren't the problem. The problem is that the tails of the AN426AD3's when
not driven are nearly below the surface of that doubler so they are about
impossible to get at. Compound that with the fact that they ARE NOT
perpendicular to the doubler plate (the flange on that rear spar is at an
angle to the doubler) makes them pretty tough to get at. Laying a bucking
bar flat on the 470's and driving the AD3's in the flange will just lay them
over.
Clear as mud?? I'll try to get a pic to explain.
Bill
Sent: Wednesday, February 24, 2010 12:21 PM
Subject: Re: How did you set these rivets
Bill,
these small rivets.
Todd Stovall
728TT (reserved)
william(at)gbta.net
PostPosted: Wed Feb 24, 2010 4:01 pm    Post subject: How did you set these rivets Reply with quote
The 470's weren't the problem. Problem is very little room to get to the
tails to buck the AD3's. Setting the bucking bar directly on the 470's
isn't the best way either because there is actually some angle to the AD3's.
See the attached pictures for a better description.
BTW: Sorry for the huge pictures I sent earlier. Reset the megs on my
camera to it's lowest setting. Maybe these won't take up as much space.
Bill
 Filesize:  249.56 KB
 Viewed:  7799 Time(s)
 Filesize:  265.87 KB
pitts_pilot(at)bellsouth.
PostPosted: Wed Feb 24, 2010 4:45 pm    Post subject: How did you set these rivets Reply with quote
I have a bucking bar just made for your application .... picture a soap
bar with a 'ledge' protruding from one of teh short edges.
Linn
Bill and Tami Britton wrote:
[quote] The 470's weren't the problem. Problem is very little room to get to
the tails to buck the AD3's. Setting the bucking bar directly on the
470's isn't the best way either because there is actually some angle to
the AD3's. See the attached pictures for a better description.
Bill
jcumins(at)jcis.net
PostPosted: Wed Feb 24, 2010 5:15 pm    Post subject: How did you set these rivets Reply with quote
They make a bar that will fit in their real nice. My tungsten bad has a end that has a edge with a lip that will allow the bar to be canted at the angle of the spar and skin what will fit between the rivet and the existing 470 rivet.
This bar makes riveting so simple just don’t drop it or it will ding your skins in a heartbeat. I am getting in the practice to lay carpet down on all material being bucked so if I do drop it no damage is done.
John 40864
Emp assembly (finally done primering)
 Filesize:  17 KB
 Viewed:  7795 Time(s)
PostPosted: Wed Feb 24, 2010 6:04 pm    Post subject: How did you set these rivets Reply with quote
You should be able to "free hand" an angled face bucking bar in that
spot without much of a problem. Use your thumb and forefinger to
square up the face to the surface... and tape off the bar where it
might bounce in to something you don't want to scratch.
Jeff Carpenter
40304
to the tails to buck the AD3's. Setting the bucking bar directly on
the 470's isn't the best way either because there is actually some
angle to the AD3's. See the attached pictures for a better
description.
my camera to it's lowest setting. Maybe these won't take up as much
space.
Bill
n223rv(at)wolflakeairport
Can't you use a bucking bar with an angled face? Then you don't touch
the 470's and can adjust for the angle difference...
On Feb 24, 2010, at 6:31 PM, "Billy & Tami Britton" <william(at)gbta.net>
470's aren't the problem. The problem is that the tails of the
AN426AD3's when not driven are nearly below the surface of that
doubler so they are about impossible to get at. Compound that with
the fact that they ARE NOT perpendicular to the doubler plate (the
flange on that rear spar is at an angle to the doubler) makes them
pretty tough to get at. Laying a bucking bar flat on the 470's and
driving the AD3's in the flange will just lay them over.
Bill
> Bill,
> Todd Stovall
> 728TT (reserved)
 Filesize:  14.14 KB
 Viewed:  7788 Time(s)
william(at)gbta.net
PostPosted: Wed Feb 24, 2010 6:14 pm    Post subject: How did you set these rivets Reply with quote
That looks exactly like what I need. Looks like I need to expand my bucking bar selection.
Thanks guys.
Bill--Trying to get wings done between all the mistakes and questions--Britton
RV-10
Sent: Wednesday, February 24, 2010 7:01 PM
Subject: RE: Re: How did you set these rivets
[img]cid:EB59362BB5BA48FBBCC5888459FB6396(at)BrittonPC[/img]
John 40864
 Filesize:  17 KB
