corrosion in the crank hub..
ces308
PostPosted: Mon Feb 22, 2010 7:58 pm    Post subject: corrosion in the crank hub.. Reply with quote
Hi all,
Does anyone out there know the AD on pulling the plug at the end of the crank to check for corrosion on a o-320-e2d? And is it a one time check or repetitive??
chris ambrose
172-k
N79308
ces308
PostPosted: Mon Feb 22, 2010 10:11 pm    Post subject: Re: corrosion in the crank hub.. Reply with quote
Never mind all....I found it.....98-02-08,if anyone was looking...
chris ambrose
dsleepy47
PostPosted: Mon Feb 22, 2010 10:49 pm    Post subject: corrosion in the crank hub.. Reply with quote
Sorry, here is the link I wanted to send: http://www.lycoming.textron.com/support/publications/service-bulletins/index.html
Deems
[quote] Subject: corrosion in the crank hub..
Date: Mon, 22 Feb 2010 19:58:43 -0800
To: lycomingengines-list(at)matronics.com
--> LycomingEngines-List message posted by: "ces308" <ces308(at)ldaco.com>
Hi all,
chris ambrose
172-k
N79308
http://forums.matronics.com/viewtopic.php?p=287751#287751
&g========================Hotmail: Free, 69228/direct/01/' target='_new'>Get it now.
dsleepy47
N1491R
dsleepy47
PostPosted: Mon Feb 22, 2010 10:50 pm    Post subject: corrosion in the crank hub.. Reply with quote
The short answer is yes and no. Uncoated (not stamped PID) crankshafts have a repetitive inspection until coated or removed from service. If no pitting is found the SB has instructions on coating and marking the crankshaft and after the coating no inspection is required. The SB does not apply to engines shipped new after 2/15/1997. The recurring requirements depend on if the crankshaft is pitted or not.
Go here for a copy of the service bulletin.
Deems
Subject: LycomingEngines-List: corrosion in the crank hub..
Hi all,
chris ambrose
172-k
N79308
Hotmail: Trusted email with powerful SPAM protection. Sign up now. [quote][b]
dsleepy47
N1491R
ces308
PostPosted: Mon Feb 22, 2010 11:46 pm    Post subject: Re: corrosion in the crank hub.. Reply with quote
Thank you very much !
chris ambrose
