chris Sinfield
Joined: 28 Nov 2006 Posts: 270 Location: Sydney Australia
Posted: Fri Feb 19, 2010 2:19 am Post subject: naca duct |
Ok Ask twice measure twice cut once..
on the FWD NACA ducts in the cabin, is the rear face (straight part) supposed to run at 90 deg to the flat top longeron?
I have the older plans and the new plastic NACA duct. At the moment it is sitting nicely between the L angles but they run at an angle and so the rear of the cut out would not be 90 deg to the horizontal.
chris..
jaybannist(at)cs.com Guest
Posted: Fri Feb 19, 2010 4:49 am Post subject: naca duct |
Chris,
The photo shows where I placed mine. I put it in that location and attached the eyeball outlet directly to the plastic duct outlet.
Jay Bannister
--> Zenith601-List message posted by: "chris Sinfield" <chris_sinfield(at)yahoo.com.au (chris_sinfield(at)yahoo.com.au)>
141.76 KB |
4021 Time(s) |
102.98 KB |
4021 Time(s) |
tigerrick(at)mindspring.c Guest
Posted: Fri Feb 19, 2010 5:53 am Post subject: naca duct |
Hi, Chris!
My favorite solution is to used the aluminum Aveo Ball Vent with a 1.75" rear sleeve, popped right into the outlet of the NACA vent. A couple of wraps of tape around the sleeve makes for an airtight fit between the vent and the duct, and you're done!
Here are a couple of shots of my installation, one with the sleeve only installed, and another with the vent part threaded in. Easy peasy.
Rick Lindstrom
N42KP
1.25 MB |
4017 Time(s) |
1.18 MB |
4017 Time(s) |
