rparigoris
Posted: Wed Feb 17, 2010 10:26 pm Post subject: What does Ducati warning light tell you? |
Hi group
I am planning panel at moment for where to position warning and indicator lights (LEDs).
I can find in many Rotax manuals specifications for Ducati regulator warning light and how to hook up. After over an hour of searching piles of documentation I still can't find what the indicator is supposed to do and indicate.
I imagine it will probably glow when voltage falls below some threshold indicating there is no charging going on, but I am not sure. Is that all it does, or does it perhaps flash to indicate over voltage? Somehow indicate something else?
Answer appreciated, but answer and pointing me where Ican find that information specifics gets a double dose of appreciation.
Ron Parigoris
air.guerner(at)orange.fr Guest
Posted: Thu Feb 18, 2010 4:35 am Post subject: What does Ducati warning light tell you? |
Hi Ron,
I do not know of any documentation on how this light works but based on my experience in the field this is what I can tell you:
The only thing it does is indicating whether the integrated permanent magnet alternator is supplying power or not.
1. Engine not running, battery master on, alternator master on: le light is on.
2. Engine not running, battery master on, alternator master off (which means alternator disconnected from the bus): the light is off.
3. Engine running, battery master on, alternator master on: the light is off: this is the normal condition.
4. Now if you turn the alternator master switch off, the light does not turn on. This is because the alternator is still supplying power.
5. From the normal condition 3. above: if you experience an overvoltage (due to regulator failure) the light does not turn on.
6. From the normal condition 3. above: if you experience an undervoltage the light does not turn on.
As a conclusion, it would be nice to have a separate warning device for under/overvoltage conditions.
Hope this helps
Remi Guerner
F-PGKL
