Are home grown temperature probes feasible?
rparigoris
PostPosted: Tue Feb 16, 2010 7:38 pm    Post subject: Are home grown temperature probes feasible? Reply with quote
Hi Bob and IraI am not at the hangar at the moment but took a look at data sheet:http://www.st.com/stonline/books/pdf/docs/2158.pdfTO-92 looks like what Ilec is using, you can see the adjustment on the datasheet I speak about, thus can match all senders so they are equal, then i can adjust my Ilec to read correctly from any sender. We are all on the same page. I may have confused speaking how Ilec does things, since they are only meant for 1 sender, they do hocus pocus in their unit to adjust and compensate for any tolerance error on senders part. In my case forcing the unit that is already installed to read correctly off of multiple senders, i will just adjust all senders to be equal, then adjust unit.Ron Parigoris [quote][b]
