Drilled hole in wrong place
william(at)gbta.net
PostPosted: Mon Feb 15, 2010 8:35 pm    Post subject: Drilled hole in wrong place Reply with quote
As I was getting ready to start riveting on my top wing skins today I found a mistake I made when drilling out my top inboard wing skin nutplate holes on the inboard side. On page 16-2 step 3 we are to drill out to #19 screw holes on the inboard edge of the W-1002 inboard wing skin. I somehow missed one of the holes by one. It is the hole directly below (aft) of the center rivet line on the skin ( rivet line where the W-1028 wing box J-stiffeners are riveted to). The enlarged hole is supposed to be the hole directly aft of that center rivet line. As you can see from the picture I messed up and drilled the second hole aft and countersunk it for a #8 screw dimple.
Are these nutplates for the wing root fairings? If so,can I use a K-1000-08 nutplate here also and modify the wing root fairing? If not are there any other suggestions? Looks to me like If I start over I'll probably have to buy new skins (made the same mistake on both wings), and ribs (since the #8 dimple countersink went into the rib).
Any thoughts or suggestions? I'll try Vans tomorrow but they are closed today for Presidents day.
Bill
 Filesize:  655.92 KB
 Viewed:  11024 Time(s)
Bob Turner
PostPosted: Mon Feb 15, 2010 8:59 pm    Post subject: Re: Drilled hole in wrong place Reply with quote
Well, if it were me, I'd put an AN426-5 or -6 (depending on the exact hole size) rivet into these "mistakes", call it a "feature", and move on.
Bob Turner
RV-10 QB
Kellym
PostPosted: Mon Feb 15, 2010 9:17 pm    Post subject: Drilled hole in wrong place Reply with quote
This is a common mistake, mentioned by many. You can slightly countersink the back side of your mistake, then squeeze an AN426AD5-3 or 3.5 in there to fill the hole. Then just drill through center of rivet for correct hole size, file shop head to almost flush and you are good to go. A bit less kosher method would be to fill the hole with JB weld epoxy. Or you can do as you propose drilling a new hole in the fairing. The rivet the hole shut method will be the least detectable, most durable.
Kelly McMullen
KCHD
Phil.Perry(at)netapp.com
PostPosted: Tue Feb 16, 2010 10:23 am    Post subject: Drilled hole in wrong place Reply with quote
Put one in the other wing too.. Then if anyone asks you about the
larger rivet, you can just look at them with a straight face and say,
"Didn't you get the service bulletin? You need to go read it."
Smile
Phil
william(at)gbta.net
Does anybody have maybe 4 or 5 each of AN426AD5's and AD6's you could send me (I will pay for them)? I will order some from Vans but sometimes their shipping is kinda slow and I'm at the point that I need the rivets NOW. If so you can e-mail me off list at william(at)gbta.net.
Anyway, thanks for the help. Better pay a little more attention from now on.
Bill
Sent: Monday, February 15, 2010 11:10 PM
Subject: Re: Drilled hole in wrong place
Tim Olson
PostPosted: Tue Feb 16, 2010 1:09 pm    Post subject: Drilled hole in wrong place Reply with quote
If this rivet hole is in the wingwalk wing-root fairing area,
I did the same thing....it was supposed to be a single-ear
nutplate instead of double, or something like that. Drilling
it wrong isn't good, because the fairing is already pre-drilled,
so then you'd have 2 holes next to eachother. The way I fixed
it was fill the mis-drilled hole with JB weld for cosmetic
purposes and then re-drill and countersink the proper hole.
If the wing root fairing wasn't pre-drilled, I would have just
left it, but since the fairing is, you should just fix the hole.
I doubt there's a strength issue to having 2 holes drilled
and countersunk...but you just want the nutplate to hold.
After filling with JB weld I think I still riveted it properly.
Tim Olson - RV-10 N104CD
Bill
partner14
PostPosted: Tue Feb 16, 2010 1:10 pm    Post subject: Drilled hole in wrong place Reply with quote
Bill, you got a phone number? Should have listed it..... Need to know what length. Call me 916-801-8402.
Don McDonald
Date: Tuesday, February 16, 2010, 5:28 AM
Bill
get=_blank rel=nofollow>http://www.matronics.com/Navigator?RV10-List
=nofollow>http://forums.matronics.com
blank rel=nofollow>http://www.matronics.com/contribution
Don A. McDonald
40636
william(at)gbta.net
PostPosted: Tue Feb 16, 2010 6:05 pm    Post subject: Drilled hole in wrong place Reply with quote
This is exactly what I'm talking about. The plans call for a single ear
nutplate instead of a double. When I was drilling them out I automatically
drilled the center of the three holes on all the locations. Well, in this
one location the forward hole was to be drilled out--not the center.
Naturally it is countersunk for a #8 screw DIMPLE so it's a rather large
hole there in the wrong place. My initial intentions were to just use a
regular K-1000-08 nutplate and forget about it until talking to Scott at
Vans. He informed me that the wing root fairings come pre-punched so the
hole really needed to be moved to the correct location.
Anyhow, sounds like JB weld should be a rather quick and easy fix.
To those of you who offered to send me rivets---Thanks a million but looks
like for now I won't be needing them.
Tim, if you read this I might drop you an e-mail for some specific details
if you can remember that far back.
Bill
Sent: Tuesday, February 16, 2010 1:25 PM
> countersunk it for a #8 screw dimple. Are these nutplates for the wing
> went into the rib). Any thoughts or suggestions? I'll try Vans tomorrow
> Thanks,
> Bill
william(at)gbta.net
PostPosted: Tue Feb 16, 2010 6:44 pm    Post subject: Drilled hole in wrong place Reply with quote
Talked to Vans about it and his suggestion was to use this route (the enlarged rivet mentioned below). It looks like if I move the hole to the correct location that the new countersink is going to overlap the incorrect countersink in the skin. I'm afraid this might leave a fairly large "loose" section on the skin. I'd like to hear from others who have made this mistake and see how it worked out for you.
Also, I need a source for AN426AD5 and AD6 rivets.
Bill
pietflyr(at)bellsouth.net
PostPosted: Tue Feb 16, 2010 7:35 pm    Post subject: Drilled hole in wrong place Reply with quote
Order them from Aircraft Spruce and Specialty and they will ship today.
Jack Phillips
#40610
Raleigh, NC
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Billy & Tami Britton
Sent: Tuesday, February 16, 2010 8:28 AM
Bill
href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-Listhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c
Kelly McMullen
Any airline mechanic or shop that works on twins and up. I found AD5
fit perfectly. Formed up nicely with my squeezer set for bare minimum
shop head remaining. It does hold the skins together until you get
around to doing the nutplate. IIRC, I don't think I did the
countersink in new location until after riveting the nutplate in
place.
On Tue, Feb 16, 2010 at 10:45 AM, Billy & Tami Britton <william(at)gbta.net> wrote:
Bill
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
Tim Olson
PostPosted: Tue Feb 16, 2010 7:38 pm    Post subject: Drilled hole in wrong place Reply with quote
Interestingly, this is one of the "gotchas" I have listed on my site:
http://www.myrv10.com/tips/gotchas.html
Included is even a picture of the offending location. I put it there
in 2005 or maybe it was 2004. Smile
automatically drilled the center of the three holes on all the
locations. Well, in this one location the forward hole was to be
drilled out--not the center. Naturally it is countersunk for a #8 screw
DIMPLE so it's a rather large hole there in the wrong place. My initial
intentions were to just use a regular K-1000-08 nutplate and forget
about it until talking to Scott at Vans. He informed me that the wing
root fairings come pre-punched so the hole really needed to be moved to
looks like for now I won't be needing them.
details if you can remember that far back.
Bill
>> rib). Any thoughts or suggestions? I'll try Vans tomorrow but they
>> Thanks,
>> Bill
ricksked(at)cox.net
PostPosted: Tue Feb 16, 2010 7:55 pm    Post subject: Drilled hole in wrong place Reply with quote
Now Kelly may have a good source but some builders may be far from an A&P hack shop..So I'm advising off the cuff but check with Wicks or Aircraft. Spruce....you might have to buy like an 1/8th pound but it will be pretty inexpensive...
Sent via BlackBerry by AT&T
40950(at)rv10.net
PostPosted: Tue Feb 16, 2010 7:56 pm    Post subject: Drilled hole in wrong place Reply with quote
Bill,
I have an assortment of 426AD5s and 6s, way more than I'll ever need so send me an address at the below email and I'll drop a few in the mail. No charge. I'll need something some day maybe you can help out.
Tom Koelzer
#40950 Empennage Attach
40950(at)rv10.net
Bill
william(at)gbta.net
PostPosted: Tue Feb 16, 2010 8:57 pm    Post subject: Drilled hole in wrong place Reply with quote
Thanks Tim. I'll definitely be checking out your "gotchas" a little closer
now. Thanks for the e-mail also. Now that the excitement and worry about
my latest mistake is gone I can get back to building. I do have to say
that it makes me feel a little better that "the man" made the same mistake I
did. LOL!!!!! Just kidding Tim!!
Thanks again to everybody who replied. I usually only monitor this list
but it really comes in handy when you need it.
Bill
Sent: Tuesday, February 16, 2010 9:16 PM
> automatically drilled the center of the three holes on all the locations.
> Well, in this one location the forward hole was to be drilled out--not
> the center. Naturally it is countersunk for a #8 screw DIMPLE so it's a
> rather large hole there in the wrong place. My initial intentions were
> to just use a regular K-1000-08 nutplate and forget about it until
> talking to Scott at Vans. He informed me that the wing root fairings
> come pre-punched so the hole really needed to be moved to the correct
> location.
> Thanks,
> Bill
> From: "Tim Olson" <Tim(at)myrv10.com>
> To: <rv10-list(at)matronics.com>
>>> aft and countersunk it for a #8 screw dimple. Are these nutplates for
>>> the #8 dimple countersink went into the rib). Any thoughts or
>>> Presidents day.
>>> Thanks,
>>> Bill
partner14
PostPosted: Tue Feb 16, 2010 10:54 pm    Post subject: Drilled hole in wrong place Reply with quote
Just so you guys know..... I have most of the sizes of rivets... 1 each, 100 each, 426's or 470... 3's 4's 5's 6's... so if it comes down to ordering a pound or 5 pounds, send me an email.
Don McDonald
Date: Tuesday, February 16, 2010, 7:45 PM
--> RV10-List message posted by: ricksked(at)cox.net (ricksked(at)cox.net)
Don A. McDonald
40636
