panel
armywrights(at)adelphia.n
PostPosted: Wed Apr 19, 2006 3:11 pm    Post subject: panel Reply with quote
Anyone willing to relate how much they paid to get their panels done for them?  Thinking about using Stein or others and wondering what all of you have paid….
Rob #392
dav1111(at)cox.net
PostPosted: Wed Apr 19, 2006 5:47 pm    Post subject: panel Reply with quote
Stein charges $5,000.00 for doing a panel, unless he has gone up on his price, and worth every penny.
Russ Daves
[img]cid:003201c6641b(at)D43G8741[/img]
 Filesize:  192.21 KB
 Viewed:  301 Time(s)
GenGrumpy(at)aol.com
PostPosted: Wed Apr 19, 2006 5:50 pm    Post subject: panel Reply with quote
Rob - you'll get what you pay for.
I paid about $55k for mine from Avionics Systems.  Think they have a picture of mine posted now.  First time I've ever held a Lexus in my hands......
But, I designed and got what I asked for.  Could not have done this same panel myself.
Grumpy
no not post
In a message dated 4/19/2006 6:15:28 PM Central Standard Time, armywrights(at)adelphia.net writes:
Rob #392
Dick Sipp
PostPosted: Wed Apr 19, 2006 6:02 pm    Post subject: panel Reply with quote
Rob,
The price to get the panel done will vary all over the place depending on the equipment ordered, etc. etc.
I made up my equipment list and then sent the same  email request for quotes to all the major shops so that I could compare apples to apples.
The bids were amazingly close, so I ended up going with the folks I thought were most experienced and that I felt most comfortable with.
I think any of the established major shops would do fine.  You will be working with them extensively before the panel is done so look for folks you can work comfortably with.
do not archieve
Dick Sipp
40065
stein(at)steinair.com
PostPosted: Wed Apr 19, 2006 7:29 pm    Post subject: panel Reply with quote
I'll not comment too much on this thread other than to say that there really is NO typical price for "doing a panel" at all.  It will vary wildly, and you'll find that almost all of the good panel shops including Avinoics Systems & Aerotronics (and us) will all end up really close in price (probably within a few % of each other).  The typical person probably won't get a panel done for $5K from any of us.  Russ forgot to mention that we used his panel as a display panel at Oshkosh 2005, along with some other "horse trading" so costs below aren't really typical.  If you've seen Mr.Miller's panel or any of the others turned out by Avionics Systems and Aerotronics you'll see they do some great work and that they can be worth every cent you spend.  I respect my competition a lot, Gary & David are two top notch guys who run top notch shops and I'm happy to say we all get along wonderfully (at least that's what I think:).  There is no way any one of us can do everyone's panels, so we all know there is plenty of work to keep us all busy.
Please don't take this as "stumping" because I really don't intend for that to be the case.  Moreover I just wanted to try and explain that there isn't a typical charge for things like this.  It depends almost entirely on what you buy, what you want installed and how, finishing options, timeframe, etc..  I'll leave you with a parting thought on things like this....
You can have your panel (or anything else aviation for that matter) with the options below:
1) FAST
2) CHEAP
3) GOOD (High Quality)
Here's the catch....you only get to pick TWO out of the three options.  Pick any two and that's the formula we all use to calculate your panel costs!
Stein.
[quote] --
dav1111(at)cox.net
PostPosted: Thu Apr 20, 2006 2:27 am    Post subject: panel Reply with quote
My apologies to Stein for the low ball price quote.  The reason I said "if he hasn't gone up" was because I felt that for what he did, a price of $5,000.00 for labor to build a panel was a steal.  I did agree to have my panel displayed at OSH 2005 as part of the deal and failed to factor into Stein's price quote any extra discount for such.
I am an attorney for an US & International Avionics Company, and the President of such company had great things to say about Stein's panel work when he saw my panel (front and back side before install).  Am I happy with SteinAir?  You bet, and I plan on having my -10 at OSH 2006.
Russ Daves
Tim(at)MyRV10.com
PostPosted: Thu Apr 20, 2006 5:03 am    Post subject: panel Reply with quote
Not trying to cut any business from any of the panel builders, but...
I thought before when people posted their bios that there was a
pretty high percentage of geek builders on the list. I fit into
that category. I'm kind of surprised that with the -10 everyone just
assumes they have to have someone build is as opposed to doing it
theirself. If you can wire a car stereo, build network cables, and
make serial cables for PC or controller interfacing, then this stuff
isn't necessarily beyond your reach. As I see it, right if you need
your panel done, you should expect to wait at least 6 months minimum
for most of the shops to get to it. If you go with places like
Aerocraft, with the recent departures of some of their expertise,
I'd bet you need more than a year lead time. There are so many -10's
coming up that there's no way the homebuilt panel industry can handle
all the work that's headed their way. What makes people so fearful
of just digging in on a D-I-Y panel? It's the one way you can
have #1, 2, and 3 of Stein's post, as long as you do good work, and
after you're done you'll understand the inner workings better.
Stein was infinitely helpful in getting my panel to come out the way
it did, as I learned a lot from him. I'm sure if you went to a guy
like him for your avionics, you could get a few tips along the way
too.
Of course, if you're not a geek, by all means you're perhaps better
off farming it out. Just wondering how the whole panel thing
turned into almost 99% professional built when the -10 came out.
you have paid….
Rob #392
jjessen(at)rcn.com
PostPosted: Thu Apr 20, 2006 6:07 am    Post subject: panel Reply with quote
I do not consider myself a geek, I just like to learn about and build
things. Thus, I'm doing my own panel, but I think others may be going the
route of the pros simply because of all the alternatives and gotches that
may be lurking behind the glass. There is also a need to get in the air,
which I feel, but I weigh that against a life-long desire to do it myself.
The problem for many is, of course, time. Money, too, but time is so
limited, and it's the engine and panel where this plane really lives and
helps you live. Building the body is easy compared to the engine and panel,
and it's the latter two that you depend so greatly on.
On my web site I've decided to document the learning journey I'm going to
take to get to the finished panel. The questions that I've asked and
answered, the alternatives, both in terms of functionality and cost, and so
on. I will have panel pictures of those who have already completed theirs,
and a critique of their approach as it relates to my decisions, as well as
links to their panel discussions. Tim's done a great job of this as well,
and the more of us do it the better. A structured approach to panel
building is what we need. Hopefully, given the accumulated body of
knowledge out there we can gather all the necessary questions. Stein and
others are very busy trying to stay up with the onslaught, but maybe they
could think about posting some of the critical decision questions they find
all of us should be asking.
John Jessen
~328 (final deburrrrrring of Tailcone)
LIKE2LOOP(at)aol.com
PostPosted: Thu Apr 20, 2006 10:25 am    Post subject: panel Reply with quote
In a message dated 4/20/06 9:07 am, Tim(at)MyRV10.com writes:
<< . I'm kind of surprised that with the -10 everyone just
theirself. >>
Tim,
Thanks for chiming in. I am planning to build my own panel...all the posts
were making wonder if there was some mystery I was unaware of.....
Steve
Port St. Lucie, FL
772-475-5556
Sent from my Treo 600
10flyer(at)verizon.net
PostPosted: Thu Apr 20, 2006 11:08 am    Post subject: panel Reply with quote
I did most of the wiring in my panel as far as switches and breakers. I
installed an Approach Hub system after having the panel cut and painted. I
was very happy with the simplicity. Tell them what equiptment you have, they
will send the harnesses and Hub. One end goes in the avionics tray, the
other in the hub. Just hook up PWR/GND/DIMR and you're good to go!!. I think
the whole set-up was about $1800. Just another way to get it done.
deej(at)deej.net
PostPosted: Thu Apr 20, 2006 12:11 pm    Post subject: panel Reply with quote
theirself. >>
Tim,
FWIW, I'm also going to wire my own panel, and likely even
do all the cutouts myself as well. No great mystery, just
time and learning as with the rest of the project... Smile
-Dj
schmoboy
PostPosted: Thu Apr 20, 2006 12:25 pm    Post subject: panel Reply with quote
theirself. >>
Tim,
the posts
Steve
Well, some of us have experience with metal work. Some of us have
experience with fiberglass. Some of us have experience with wiring.
Some of us have experience with engines. Some have experience with
painting. The lucky few have experience with all the above or have a
close resource who has experience to oversee.
And some of us have experience with only one of the above and feel
more comfortable paying someone else to do it.
To each his own.
-Sean #40303
johnwcox(at)pacificnw.com
PostPosted: Thu Apr 20, 2006 6:39 pm    Post subject: panel Reply with quote
For the many who are taking the effort to build their own panel, Good
for you. Tim Olson has done a remarkable job showing each of the steps
and how easy it is (was). I can direct any of you to firms that can do
just the panel cutting, just the silk screen, just the wire runs or just
the avionics purchases. It is much easier and more valuable long term
than the money invested in turning the entire project over.
Kitplanes did an excellent article some time back on what makes a great
visually appealing panel with high utility. However, one person's Lexus
can be another's Yugo. And it won't stand the test of being resold to a
third party down the road. Legions can be learned by reading and
studying why Tim selected specific items and why they were placed where
they were. Knowing the wiring (Aero-electric)is a whole nother notch on
the educational road to experimental kit built.
Thanks Tim... cheers to you Steve, the community will be better for more
custom Lexus and fewer mass produced Yugos. Every panel should be a
Lexus.
John - KUAO
Do not Archive
pitts_pilot(at)bellsouth.
PostPosted: Thu Apr 20, 2006 7:08 pm    Post subject: panel Reply with quote
The biggest challenge to anyone wiring their own panel is getting good soldered connections.  I use a Weller Solder Station .... the one with the interchangeable, temperature controlled tips.  It's pricey ...... no, not like avionics .... but even a neophyte can solder acceptably with it.  Just be careful and not use too much solder, don't carry solder to the joint on the soldering iron, and get the joint hot enough so it melts the solder, not the iron directly.  I also like to use clear heat-shrink tubing over the connection .... especially on the d-sub connectors.
Linn
Dj Merrill wrote:
--> RV10-List message posted by: Dj Merrill <deej(at)deej.net> (deej(at)deej.net)
LIKE2LOOP(at)aol.com (LIKE2LOOP(at)aol.com) wrote:
--> RV10-List message posted by: LIKE2LOOP(at)aol.com (LIKE2LOOP(at)aol.com)
In a message dated 4/20/06 9:07 am, Tim(at)MyRV10.com (Tim(at)MyRV10.com) writes:
theirself. >>
Tim,
-Dj
dmasys(at)cox.net
PostPosted: Fri Apr 21, 2006 6:18 pm    Post subject: panel Reply with quote
I cut the panel for my -7A and wired all of the avionics from schematics downloaded from the web. Result is at:
http://array.ucsd.edu/rv7a/panel.html
and
http://array.ucsd.edu/rv7a/2003-02-16_panel2.jpg
Took about 200 hours to do all of the design, cutting, wiring and painting, but it was one of the really fun parts of the project. Plan to do the same for the -10.
-Dan Masys
#40448
