mhilderbrand
Posted: Thu Feb 11, 2010 3:58 pm Post subject: Cold CHTs |
Flying in the colder weather (20-30deg F) I have the following CHTs:
148 155 199 169 194 202 (1,3,5,2,4,6) This is at 2790 RPM
I am in the process of closing off the in lets to the heads in order to bring the temps up. Are there any MAJOR problems I might have created with such low CHT's?
My mag checks are showing a significant drop....(right at, and sometimes > 100) I have been blaming it on possible carbon build up. I experienced this on the Cessna I used to fly and would lean until the rpm normalizes. Today I am going to check the ignition/plug wires to make sure all is well.
Michael Hilderbrand
Derby, Kansas
Http://www.kansasflying.com
| | - The Matronics JabiruEngine-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
plus2s
Posted: Thu Feb 11, 2010 4:56 pm Post subject: Cold CHTs |
Re the mag drop - Check your coil to flywheel gaps -
Low temps are far better than high temps
Keith
--- On Fri, 12/2/10, Michael Hilderbrand <m_hilderbrand(at)sbcglobal.net> wrote:
From: Michael Hilderbrand <m_hilderbrand(at)sbcglobal.net>
Subject: Cold CHTs
To: jabiruengine-list(at)matronics.com
Date: Friday, 12 February, 2010, 12:52 PM
Michael Hilderbrand
Derby, Kansas
Http://www.kansasflying..com
ist" target=_blank rel=nofollow>http://www.matronics.com/Navigator?JabiruEngine-List
| [quote][b]
Roger Lee
Posted: Fri Feb 12, 2010 8:57 pm Post subject: Re: Cold CHTs |
In cold weather bigger mag drops are common. Adjust the carb. Even Rotax made a video about this. Cold weather verses very warm weather means leaner fuel air mix.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
