Dick Maddux
Posted: Thu Feb 11, 2010 5:30 am Post subject: Intermittent Ignition IssueIntermittent Ignition Issue |
Rique,
That is exactly the same thing that happened on my engine ! (see my prior list) I ended up replacing the P leads etc trying to find the problem but it ended up being a broken wire !. Swap connectors on your electronic boxes and see if the problem follows. I would be willing to bet you have a broken power wire to one of your modules and it is connecting intermittently.
In any case you could call Ronnie (at) South Mississippi Light Aircraft or a tech at Lockwood,LEAF or CPS and ask them about it also. Ronnie solved my problem . He knows these engines !
Dick Maddux
Milton,Fl
Float Flyr
Posted: Thu Feb 11, 2010 7:58 am Post subject: Intermittent Ignition IssueIntermittent Ignition Issue |
That sounds more than possible to me too
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Catz631(at)aol.com
Sent: February 11, 2010 9:51 AM
Subject: Re: Intermittent Ignition IssueIntermittent Ignition Issue
Rique,
Dick Maddux
Milton,Fl
| Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 0123456789
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
