Flying from East of Rockies to Vans
dwhite17(at)columbus.rr.c
PostPosted: Sun Feb 07, 2010 2:05 pm    Post subject: Flying from East of Rockies to Vans Reply with quote
Greetings:
I am starting to plan a trip from Ohio to Tacoma, Washington this summer in an RV6A. I know there have been quite few RVers out there who have made the voyage from East of the Rocky Mountains to Vans in Oregon. I was hoping some of you who have made that trip might send me your flight plan or path of travel over the Rockies.
Thanks in advance
David White
N176LD
n801bh(at)netzero.com
PostPosted: Sun Feb 07, 2010 2:47 pm    Post subject: Flying from East of Rockies to Vans Reply with quote
Weather will dictate the actual safe route but,,,, If you generally follow I-80 west, once across Wyoming you hit the Utah/Wyoming/Idaho junction. From there draw a straight line to Vans. IMHO.
Ben Haas
N801BH
www.haaspowerair.com
Kellym
PostPosted: Sun Feb 07, 2010 7:12 pm    Post subject: Flying from East of Rockies to Vans Reply with quote
Or just go direct Billings MT direct Spokane direct for lower mountains,
likely less turbulence. Either route works, just your preference for
scenery and what the weather throws at you.
Ben Haas
N801BH
Kelly McMullen
KCHD
martin(at)gbonline.com
PostPosted: Mon Feb 08, 2010 6:54 am    Post subject: Flying from East of Rockies to Vans Reply with quote
Dave,
I have flown to Vans several times from Wisconsin where I live. If you use Boseman Mt. or a little north of there, as your course line, you can make most of the trip (at) 10,000 ft or less. If you can borrow a oxygen system, it is a good safety item to have in case you have to go higher for short periods for weather etc.
Note: I experienced hypoxia on one of my first triips west. I did not have and oxygen system and I was foolishly flying above 10,000 for a fairly long period.. I realized it when I attempted to perform routine course corrections and had difficulty doing it-----
Good Luck.
Dick Martin
RV8 N233M
the fast one
[quote] From: David L. White (dwhite17(at)columbus.rr.com)
To: rv-list(at)matronics.com (rv-list(at)matronics.com)
Sent: Sunday, February 07, 2010 4:02 PM
Subject: Flying from East of Rockies to Vans
Greetings:
Thanks in advance
David White
N176LD
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
gcomfo(at)tc3net.com
PostPosted: Mon Feb 08, 2010 1:16 pm    Post subject: Flying from East of Rockies to Vans Reply with quote
