bw12345(at)sbcglobal.net Guest
Posted: Mon Feb 08, 2010 4:49 am Post subject: Prop Position |
On the 2200 I purchased used the prop is mounted in the 7 o'clock position.On my other engines it was mounted in the 10 o'clock position on compression so they could be hand prop-ed. Does it make a difference as I would like to have the option to hand prop&==
| | - The Matronics Jabiru-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Jabiru-List |
Clive J
Posted: Mon Feb 08, 2010 5:23 am Post subject: Prop Position |
You won't hand prop start a Jabiru, unless it's spinning on a starter it
won't produce a spark good enough apparently. Not like an impulse mag,
it's just a dumb coil.
The best place to mount the prop is 9 o'clock, this so it's out the way
if it ever stops and you have to land it in a field.
Regards, Clive
Posted: Mon Feb 08, 2010 6:54 am Post subject: Prop Position |
Thanks Clive
BOB
Jaba-who
Joined: 17 Feb 2010 Posts: 4 Location: Cairns, Australia
Posted: Tue May 18, 2010 1:17 am Post subject: Re: Prop Position |
Yep.
The Jabiru engine has to have the prop turning at about the instantaneous equivalent of about 750 rpm to fire. Not possible by hand I'm afraid.
info(at)flylightning.net Guest
Posted: Tue May 18, 2010 4:44 am Post subject: Prop Position |
Not sure what that means but it does take 295RPM for the Magnetos to produce
the field and discharge needed to fire.
Nick
