Ga$
Larry Bowen
PostPosted: Wed Apr 19, 2006 6:29 am    Post subject: Ga$ Reply with quote
Last I overheard, Stanley Cty (VUJ) was the cheap place for fuel. So
without verifying, I went there to fill up last night...$3.64. Ouch.
On a related note, I've started cruising at lower power settings, 21 MP/23
RPM instead of the 23/23 I've been using. Cooler CHTS, at least 1 Gal/Hr
less fuel and 6-7 Kts slower....
Larry Bowen
Larry(at)BowenAero.com
http://BowenAero.com
Larry Bowen
RV-8 SOLD,
RV-7QB in progress...
View user's profile Send private message Visit poster's website AIM Address MSN Messenger
ddavenport5(at)nc.rr.com
PostPosted: Wed Apr 19, 2006 7:33 pm    Post subject: Ga$ Reply with quote
Guys, FYI, Elizabethtown, NC (EYF) is pricing 100LL at 3.25 right now. Just
in case anyone is going that way,
David
RV-6 168DD
sawad13(at)msn.com
PostPosted: Thu Apr 20, 2006 3:45 am    Post subject: Ga$ Reply with quote
If you guys want to save some bucks on gas, why not use auto gas? Or at
least a autogas av gas blend?
Ron Awad
[quote]From: "David Davenport" <ddavenport5(at)nc.rr.com>
Reply-To: rvsoutheast-list(at)matronics.com
To: <rvsoutheast-list(at)matronics.com>
Subject: Re: Ga$
Date: Wed, 19 Apr 2006 23:30:45 -0400
David
RV-6 168DD
tadsargent(at)bellsouth.n
PostPosted: Thu Apr 20, 2006 4:50 am    Post subject: Ga$ Reply with quote
Chirp chirp chirp....
Stirring the pot?
Tad
sawad13(at)msn.com
PostPosted: Thu Apr 20, 2006 5:08 am    Post subject: Ga$ Reply with quote
No not stirring the pot.... if I were to stir the pot I would say something
to the effect of if you can afford a near 100 thousand dollar plane, why
worry about how much the gas costs? Kinda like the owner of a Porsche
taking his car to Walmart to get a oil change...... lol
Gas is gas and using good premium 93 Octane car gas is a alternative fuel
that will work just fine in most of our airplanes. I use it in my RV-4 with
no problems whatsoever. I save usually around a dollar per gallon over
Avgas. And for me, price of gas does make a big impact, I am a Walmart
shopper afterall.
Ron Awad
[quote]From: "tadsargent" <tadsargent(at)bellsouth.net>
Subject: Re: Ga$
Date: Thu, 20 Apr 2006 08:54:45 -0400
Stirring the pot?
Tad
bill(at)repucci.com
PostPosted: Thu Apr 20, 2006 5:49 am    Post subject: Ga$ Reply with quote
Why use 93 Octane?
If your engine is certified for 80 Octane, like mine, regular unleaded
at 87 Octane will work just fine. If your engine is certified for 100
Octane, than you shouldn't be using mogas anyway.
Bill
O-290 powered RV-9 and expecting 5.6 GPH (at) 175 mph
sportav8r(at)aol.com
PostPosted: Thu Apr 20, 2006 6:27 am    Post subject: Ga$ Reply with quote
I'll bite. I probably burn 10 gallons of hi-test mogas for every gallon of 100LL... the latest round of avgas price increases makes the $2.85 and up for 93 octane seem more bearable. Amazing how fast the American con sumer gets accustomed to higher prices.
-Stormy
PostPosted: Thu Apr 20, 2006 6:28 am    Post subject: Ga$ Reply with quote
because higher compression 160 hp engines want to have 91/96? That's my story and I'm stickin' to it.
bill(at)repucci.com
PostPosted: Thu Apr 20, 2006 12:01 pm    Post subject: Ga$ Reply with quote
I thought the minimum octane rating for these "high compression" engines
was 100, not 91/96. My mistake.
Bill
PostPosted: Thu Apr 20, 2006 12:38 pm    Post subject: Ga$ Reply with quote
Maybe for some, Bill. Certainly not for the 160 hp O-320, though.
bill(at)repucci.com
PostPosted: Thu Apr 20, 2006 3:38 pm    Post subject: Ga$ Reply with quote
Darn it, that undermines my last reason for the 140 hp O-290-D2 I'm
installing my -9. Oh, there is still that low price thing for a O SMHO
Lycoming, can't forget that.
Bill
sawad13(at)msn.com
PostPosted: Thu Apr 20, 2006 4:44 pm    Post subject: Ga$ Reply with quote
I was told by many people including the folks at the EAA that handle the
autogas STC for certified planes, that with my 0-320 160 HP engine I would
need at least 93 Octane autofuel or av gas. I ran 87 in it for a month or so
when I got it and at times I could hear some pinging so the 93 makes sence
to me. No pinging or other issues with the 93.
Bill, off topic but do you really think your bird will go that fast on that
engine and with that fuel burn? I have had 2 other planes with 0-290
engines and both burned between 6-7 gallons per hour at best. In my RV-4 I
am burning nearly 7 gallons per hour going 170 mph.
Ron Awad
[quote]From: "Bill Repucci" <bill(at)repucci.com>
Subject: RE: Ga$
Date: Thu, 20 Apr 2006 09:47:18 -0400
Why use 93 Octane?
Bill
bill(at)repucci.com
PostPosted: Fri Apr 21, 2006 5:56 am    Post subject: Ga$ Reply with quote
Ron,
All I know is what I've been told by another guy who has an O-290-D2
powered RV-9 (Tail wheel), like what I'm building. His empty weight is
998, and I suspect mine will be a bit higher.
Van's lists the cruise speed for this combination as 175 mph. From what
I keep hearing, Van's numbers are usually on the mark.
Also, the prop makes a big difference. Craig Catto cut one for me that
he suspects will get me to 180 top speed.
With all that background info, I sure am keeping my fingers crossed for
a 75% power 175 mph cruise. The GPH thing, well that may be a bit
optimistic but then again, I'll be burning regular unleaded in that 80
octane, low compression engine
Bill
bill(at)repucci.com
PostPosted: Mon Apr 24, 2006 10:34 am    Post subject: Ga$ Reply with quote
Ron,
The following was just posted as part of this thread:
http://www.vansairforce.com/community/showthread.php?t=7247
it works better than you might think
I had the chance to fly an O-235 powered RV-9A off and on for about 18
months and learned to really like the airplane. As with any RV, you make
engine choices based, no so much on the airplane as the job you will be
asking it to do.
118 hp was good enough to give the 990 lb airplane good take off and
climb and excellent cruise. I'd quite commonly cruise 155-160 mph, which
I though was pretty darn good for that hp -- especially considering that
every other airplane I'd flown with the same engine was lucky to break
100.
I may have to rethink the fuel burn a little but if that holds up, my
dream of a 175 mph RV on only 135 hp sounds like a possibility, more so
since I won't have the nose wheel to slow me down.
Bill
