jchang10
Posted: Thu Feb 04, 2010 9:20 am Post subject: Starter contactor wiring B11 |
http://picasaweb.google.com/jchang10/DropBox?authkey=Gv1sRgCI7088GZlYCc2AE#5434438361737026322
Could someone explain what exactly the B11 wire does in Van's wiring
plans? I cropped an image in the link above.
For one, it seems redundant if one were to keep the jumper on the solenoid.
Also, Knuckolls uses the I terminal for an indicator light, but clearly,
that is not how it is being used here.
Jae
40533
_________________ #40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011 |
Jim Berry
Posted: Thu Feb 04, 2010 11:01 am Post subject: Re: Starter contactor wiring B11 |
Jae,
I posed this question some time back to both Van's and Skytec. Skytec said they wished that the Vans drawing never existed, and insisted that their way was correct for their starter. The response I got from Van's was that it was complicated. When I asked them to elaborate, they never responded.
There was also some recent discussion about this on the Aeroelectric list, with Bob Nuchols offering his interpretation.
Jim Berry
40482
N15JB
jchang10
Posted: Thu Feb 04, 2010 11:41 am Post subject: Starter contactor wiring B11 |
http://www.aeroelectric.com/articles/strtctr.pdf
Thanks Jim. Well, for now, I will just stick with the skytec
installation
http://skytecair.com/images/Certified%20ST2%20Installation%20Wiring_1100.jpg
From the PDF above, and my own assumptions, it seems like Vans wiring
is very strange. i guess it might work but is sure an odd way to go
about it.
Jae
Jim Berry wrote:
Jae,
Jim Berry
40482
N15JB
http://forums.matronics.com/viewtopic.php?p 84862#284862
jchang10
Posted: Fri Feb 05, 2010 8:47 am Post subject: Starter contactor wiring B11 |
http://www.skytecair.com/Wiring_Diag.htm
As a final follow-up, the above link actually gives detailed
instructions specifically for RV-10 builders at the bottom of the page.
I had not scrolled down far enough initially. I haven't verified all the
model numbers, but I am assuming everyone has the NL starters as
indicated on that page.
Jae
40533
