aerosport1
Posted: Fri Feb 05, 2010 3:06 pm Post subject: New G900 Carbon Fiber panel |
The picture attached is the first carbon panel out of the mold. The panel was designed specifically for the Garmin G900 avionics. They will be available Thru
http://www.aerosportproducts.com
These panels will use all the same lower console pieces as our standard panel.
It will also fit with the carbon center armrest console as well as the throttle
quadrant kit.
69.66 KB |
2036 Time(s) |
690.82 KB |
2036 Time(s) |
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
