jloram
Joined: 07 Nov 2009 Posts: 54 Location: United States
Posted: Wed Feb 03, 2010 4:03 pm Post subject: Thermocouple compatible bulkhead connector? |
Does any one know of a source (other than Omega) for multi-pin bulkhead
connectors that are compatible with Type J & K thermocouples? I wiring the
firewall foreword...
thanks, -john-
| | - The Matronics Avionics-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Float Flyr
Posted: Fri Feb 05, 2010 7:47 am Post subject: Thermocouple compatible bulkhead connector? |
John:
My advice would be to just use a grummet. The wires on thermocouples have
to be a consistent types of metal from the couple itself to the instrument.
Finding a multi pin bulkhead fitting in the exact correct metals may be
difficult if not impossible.
If your plane is certified be sure to follow AC43 for specs on cable
supporting.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
rjquillin(at)cox.net Guest
Posted: Fri Feb 05, 2010 8:07 am Post subject: Thermocouple compatible bulkhead connector? |
At 07:47 2/5/2010, you wrote:
| Quote: | The wires on thermocouples have
to be a consistent types of metal from the couple itself to the instrument. |
I don't believe as stated that's entirely true.
A voltage is developed across a junction of differing metals, that's why a TC works, but...
If a transition is made from conductor metal type A, to conductor metal type B, we'll assume some voltage +E is developed. However, when transitioning back from conductor metal type B to conductor metal type A, voltage E is again developed, but it is now -E. When both transitions are at the same temperature, the voltages cancel one another out and minimal if any error voltage is generated.
We do this all the time in a thermal-vacuum chamber used for NASA satellite/spacecraft verification all the time and it's quite acceptable; assuming the transitions are at a constant or nearly so temperature. While the instrument within the chamber is cycled from ~ +85C to ~ -100C, the transition connector remains near ambient ~ +22C. Errors are minimal and well within acceptable limits.
Ron Q.
kcarey(at)alum.mit.edu Guest
Posted: Fri Feb 05, 2010 8:37 am Post subject: Thermocouple compatible bulkhead connector? |
Have you checked with the manufacturer of the EGT/CHT system you're using?
I have an EI UBG-16 and when I checked with EI, they didn't have a problem
with using a standard multi-pin connector at the bulkhead. There are
already two pretty common looking multi-pin connectors in the harness for
the EGT and CHT leads installed at the factory.
Kevin
jloram
Posted: Fri Feb 05, 2010 10:50 am Post subject: Thermocouple compatible bulkhead connector? |
You're quite correct Ron. Somehow I had failed to notice that I would be creating two, opposite polarity junctions that would be "isothermal"...
Now, I just need to find a cheap source for mil spec circular connectors (MIL-C-5015). Anybody have a favorite source? I need a bulkhead and plug connector with 24 pins for the thermocouples.
thanks all for comments, -john-
[quote] From: owner-avionics-list-server(at)matronics.com [mailto:owner-avionics-list-server(at)matronics.com] On Behalf Of Ron Quillin
Sent: Friday, February 05, 2010 8:07 AM
To: avionics-list(at)matronics.com
Subject: RE: Thermocouple compatible bulkhead connector?
Ron Q.
href="http://www.matronics.com/Navigator?Avionics-List">http://www.matronics.com/Navigator?Avionics-List
| [b]
jloram
Posted: Fri Feb 05, 2010 10:55 am Post subject: Thermocouple compatible bulkhead connector? |
Turns out that such connectors do exist in several different version. You
buy the pins separately to match the thermocouple wire. Pins cost about $20
each. However, I've finally realized that it won't be necessary to use a
special connector. (see other posts on same subject).
I'm determined not to have to disconnect 24 wires for thermocouples every
time I want to pull the engine.
-john-
[quote] --
rampil
Posted: Fri Feb 05, 2010 11:55 am Post subject: Re: Thermocouple compatible bulkhead connector? |
Amphenol certainly makes TC compatible pins for J & K combos.
You might be able to request samples. These pins are usually not
stocked at Digikey or Newark, etc, but that does not mean they are
not potentially available. Check the Amphenol catalogs for your choice
in metal or plastic circular connectors.
Float Flyr
Posted: Fri Feb 05, 2010 11:59 am Post subject: Thermocouple compatible bulkhead connector? |
As far as i know for certification the metals have to be consistant... If the plane is not certified that is not a requirement.
Noel
Sent: February 5, 2010 12:37 PM
Ron Q.
| Quote: | | http://www.matronics.com/Navigator?Avionics-List | 0123456789
Kitfox III-A
berkut13(at)berkut13.com Guest
Posted: Fri Feb 05, 2010 1:29 pm Post subject: Thermocouple compatible bulkhead connector? |
I've used the 38999 series Mil connectors (with std gold pins) with great success for all kinds of firewall connections - including K and J type thermos. Flame Enterprises as a distributor for Mil-everything.
http://www.flamecorp.com/
The CPC Series 2 connectors are also good, but they are plastic - not recommended for use on the firewall. You can get those from all the usual suspects - Mouser, Digi-Key, Allied, etc. I have not used them, but they may come in a metal form factor...dunno.
James Redmon
Berkut #013/Race 13
www.berkut13.com
rampil
Posted: Tue Feb 09, 2010 8:39 am Post subject: Re: Thermocouple compatible bulkhead connector? |
I think someone is confused here.
The purpose for keeping the alloys the same in the path to the voltmeter
for T/C measurement has nothing to do with certification. It has to do
with Accuracy! If there is a point where the metal changes, it creates a
new thermocouple (usually a "cold point") These additional thermocouples
will change the net voltage at the voltmeter and thus the temperature reading. There is almost always a cold junction at the meter itself to
contend with. If you have several cold junctions in the loop at different
temps and all in the same direction of metal change, your reading will
be very inaccurate. Yes, even if the pins are gold plated!
But then, who among us ever bothered to test the accuracy of their
CHT or EGT probes?
Thus it has always been. Knowing the reasons for certain guidelines lets
you make sensible plans
Float Flyr
Posted: Tue Feb 09, 2010 2:51 pm Post subject: Thermocouple compatible bulkhead connector? |
I agree with your comment on the accuracy which is why if there are
dissimilar metals in the circuit of the T/C it will never get certified.
Noel
Kitfox III-A
retasker(at)optonline.net Guest
Posted: Tue Feb 09, 2010 7:27 pm Post subject: Thermocouple compatible bulkhead connector? |
Sorry, but I have to speak up regarding the confusion... While what
seems to be the consensus is literally true, in reality it really
doesn't make any difference.
The way a thermocouple works is by a phenomenon called the Seebeck
effect. This has a complicated physics description, but the net result
is that any metallic material that is exposed to one temperature at one
end and another at the other, will generate a small voltage across its
length. Each material has its own characteristic voltage per degree
difference between ends. A thermocouple takes advantage of the
different voltages by pairing two different materials - one generates
one voltage and the other generates another. Because they are connected
at one end (where the desired temperature measurement is to take place)
one can measure the voltage difference at the other end. A so called
"cold junction" compensation is usually provided in the gauge or meter
that displays the temperature so that the readout shows the actual
temperature at the far end rather than the temperature difference
between the two ends.
Ideally the same material should be used from the temperature
measurement point to the meter that displays the reading.
Practically speaking this is not necessary and is a source of a great
many old wives tales.
Take the example of a connector that has the two thermocouple wires on
each end and the connector contacts between them (i.e. thermocouple wire
from the point of interest to the connector and then thermocouple wire
from the connector to the meter). Yes, the different material of the
contacts will generate a small voltage from one end to the other based
on the temperature difference between the two ends of the connector.
What is this temperature difference likely to be? Probably less that
one degree unless it is a very long connector. Further, both sets of
pins are the same, so the net voltage generated by the connector will be
zero. So the only difference on voltage at the meter will be the very
small temperature difference between one end of the connector and the
other. Considering most of us are measuring CHT (several hundred
degrees) or EGT (1200 -1600 degrees), a degree or two is irrelevant.
If one chooses to use a connector to go through the firewall and then
use regular copper wire to connect between the firewall connector and
the meter in the cockpit, then that would cause an error that might be
measurable. If the firewall is 150 degrees and the cockpit is 70
degrees, then there will be an error of 80 degrees in the display, which
is definitely significant for what we are measuring - if we are trying
to tell what the exact temperature is. However, even in this extreme
case, the typical use of the readout is to compare the temperature of
the cylinders to each other or the EGTs to each other. Even though the
displayed temperature will not be correct, if all thermocouples go
through the same connector, they will all be affected the same and can
still be compared properly.
So...
A connector that is added to a set of thermocouple wires run from the
temperature measurement point to the meter has essentially no effect on
accuracy of the measurement. You can even add lengths of copper wire if
the temperature difference between the two ends of the copper wire are
at the same temperature. Your error in this case will be only the
difference in temperature between the two ends of the copper wire.
There are a few caveats:
All the above regarding connectors and copper wire is true if the two
wires from the thermocouple and connector and copper are run over the
same physical path so they are exposed to the same temperature
differences. If you were to use two connectors - one for each of the
thermocouple wires - placed far apart you could get errors that mattered
(why you would do this I have no idea).
The materials in the path of the two thermocouple wires must be
identical (except for the thermocouple wires themselves of course) -
that way all the other materials will generate the same voltages in each
path so the reading will be only what the thermocouple wires generate
over their length - whether they are one unbroken run or a run broken by
a connector.
If you are trying to measure temperatures of a only few degrees above
ambient, then, while the above is still true, the errors may be too much
for your requirements. If you are measuring CHT and EGT adding a
connector is irrelevant to the reading.
Dick Tasker
rampil wrote:
CHT or EGT probes?
Ira N224XS
http://forums.matronics.com/viewtopic.php?p 85636#285636
Please Note:
No trees were destroyed in the sending of this message. We do concede, however,
that a significant number of electrons may have been temporarily inconvenienced.
douglist(at)macnauchtan.c Guest
Posted: Tue Feb 09, 2010 8:32 pm Post subject: Thermocouple compatible bulkhead connector? |
At 22:12 -0500 2/9/10, Richard E. Tasker wrote, and I snipped.:
A well thought out answer that says it all. Read it,
There was a time when thermocouples in aircraft were hooked up to sensitive D'Arsonval current meters, the analog kind with a magnet, a coiled spring, and a pointer. Those meters measured current rather than voltage and that made the length and resistance of the wires important. Re-calibration would be required if, for instance, a thermocouple was shortened during installation or repair. The solid state digital voltmeters of today have no such problems.
When reading FAA rules of engagement remember that most of them were written 50 years ago.
Richard's use of the Seebeck effect in his description is accurate but perhaps more complicated than necessary, You won't go far wrong by thinking of a junction of two metals as a tiny temperature sensitive battery with a known voltage vs temperature function that you can look up in tables. The Omega Company is really good at providing those tables.
<http://www.omega.com/toc_asp/sectionSC.asp?section=A&book=temperature>
--> A fair tax is one that you pay but I don't <--
jloram
Posted: Thu Feb 11, 2010 3:05 pm Post subject: Thermocouple compatible bulkhead connector? |
Hi Ira, I agree with you in all but one detail: when I insert a connector
into a leg of a thermocouple wire I've created three junctions. One does not
generate a voltage, and the other two junctions generate equal voltages
(because they are at the same temperature) and opposite polarity (so they
cancel out).
For example: Take a piece of thermocouple wire and cut it. Crimp a brass
connector pin on one end of the cut and a brass connector socket on the
other end of the cut. Now plug the brass pin into the brass socket. The
Brass/Brass junction does not generate a voltage because it is a junction of
similar metals. However you have created two other junctions; one is
Iron/Brass and the other is Brass/Iron. These two junctions create equal
voltages (because they are at the same temperature) but the voltages are of
opposite polarity, and cancel one another out. The connector has no net
effect.
regards, -john-
[quote] --
rampil
Posted: Fri Feb 12, 2010 6:53 am Post subject: Re: Thermocouple compatible bulkhead connector? |
Hi All,
I agree with all the comments that follow my snip.
The real problem is not the absolute precision or accuracy of these systems which may each in usual practice with the cheap design gauges
(though most pricey to purchase since they carry an aviation sticker), be 10% or worse.
The issue is the basic lack of understanding in many builders (this applies
to boats and cars too!) about things electric. Simple principles of
operation are not that hard or foreign.
Understanding the most basic principles help designers from big errors, and would as a side effect, eliminate 90% of the traffic on Bob's mediated
group.
Float Flyr
Posted: Fri Feb 12, 2010 7:04 am Post subject: Thermocouple compatible bulkhead connector? |
Is it reasonable to believe if the connection is going through a bulkhead
that the temperatures will be different on each side of the bulkhead?
Noel
Kitfox III-A
Posted: Fri Feb 12, 2010 10:01 am Post subject: Thermocouple compatible bulkhead connector? |
Probably different, but by how much? The thermocouple wire is connected
on each side to a connector pin, the connector pins connected to each
other. All metallic and relatively good thermal conductors.
How accurately do you want to measure the CHT/EGT anyway? As Ira noted,
the meter is probably the "weakest link" in this accuracy equation anyway.
Dick Tasker
Noel
jloram
Posted: Fri Feb 12, 2010 10:21 am Post subject: Thermocouple compatible bulkhead connector? |
It is reasonable to believe that there is a temperature difference of a few
tenths of a degree. Not enough to be perceptible by any of the
instrumentation we're using.
-john-
[quote] --
Posted: Sat Feb 20, 2010 12:15 pm Post subject: Thermocouple compatible bulkhead connector? |
Postcard in this morning's snail mail:
TC Measurement and Control Inc.
PO Box 685
Hillside, IL 60192-9922
877 449 0700
Free 72 page "wallchart format" 16 x 12 inch complete reference manual for Thermocouple and Resistance Thermometry. Request a copy at <http://www.tc-inc.com>.
And it's NOT Omega. But I'm fairly sure there is danger of getting on yet another mailing list.
--> If it's not on fire it's a software problem. <--
vipin
Posted: Sun Dec 05, 2010 8:04 pm Post subject: Re: Thermocouple compatible bulkhead connector? |
_________________ Slimming Pills
Slimming Pill |
