jconnell(at)fmwildblue.co Guest
Posted: Thu Feb 04, 2010 2:00 pm Post subject: Fiberglassing forward fuselage skin - Tip-up |
Guys,
My RV-9A has a tip-up canopy. The forward fuselage skin is a tad low in some areas as it relates to the canopy skin. I want to match the skins by building up with a micro micro slurry then sand to match.
I'm concerned the micro might chip or separate from the aluminum in the future. My plan is to rough up and clean the forward canopy skin, lay down a layer(s) of fiberglass cloth, add peel ply and let it cure. After removing the peel-ply I'd add the epoxy/micro mixture, let it cure, then sand to match.
Will the cloth bond the micro to the skin and keep it from chipping away? The buildup in some areas could be a 1/16" or just a tad more.
I've tried to research the archives - it's a slow day on the website.
Any suggestions are welcome! Thanks...
Joe Connell
Stewartville, MN
