Fuel Flow Transducer-Injected
Goto page 1, 2  Next
alexpeterson(at)earthlink
PostPosted: Tue Apr 18, 2006 6:12 pm    Post subject: Fuel Flow Transducer-Injected Reply with quote
First question, where's a good place to put this in the
stream of fuel? I'm not too savvy on injected engines.
While talking with Electronics International today, I was
told that since there is a return of unused fuel, I'll need
TWO transducers and a little box that computes the unused
fuel. This adds about $300 to the price of my fuel flow, and
am wondering if it's worth it now. Thoughts?
Paul Besing
RV-4
N73DD
Arizona (For Now)
Paul, put it in the line between the servo and flow divider. You'll have to
add a hose, and you may need to bring those lines back to the firewall.
For others paying attention, not all fuel injection systems have this return
line (Airflow Performance, for one), making the installation as simple as a
carb with respect to fuel lines.
Alex Peterson
RV6-A N66AP 751 hours, ripping out the Lasar system this weekend.
Maple Grove, MN
dan(at)rvproject.com
PostPosted: Tue Apr 18, 2006 6:17 pm    Post subject: Fuel Flow Transducer-Injected Reply with quote
In the metered fuel line between the servo and flow divider is about as
ideal a spot as any imho.
)_( Dan
RV-7 N714D
http://www.rvproject.com
dsvs(at)comcast.net
PostPosted: Tue Apr 18, 2006 7:05 pm    Post subject: Fuel Flow Transducer-Injected Reply with quote
Paul,
The AFP has no return. The purge valve is not used during noemal operations
and this is the only source of returned fuel. Between the servo and the
flow divider is the best spot and I like Alex's idea of bringing thewe lines
to the firewall. Don
dwight(at)openweave.org
PostPosted: Tue Apr 18, 2006 7:34 pm    Post subject: Fuel Flow Transducer-Injected Reply with quote
> Paul Besing
> RV-4
> N73DD
> Arizona (For Now)
According to the folks at Airflow Performance, Alex is right on the
money regarding where to install the transducer. I don't know what FI
system you are using, but with the API system there is no return line
for _normal_ operation. There is a return line for the purge valve
but that is only used pre-start to purge vapor from the lines, and
at shutdown to _positively_ terminate fuel flow to the flow divider
(and thus insure a clean shutdown of the engine).
The API opinion on the amount of fuel returned is that it is so little
(startup and shutdown) that putting a Flowscan on the return line would
be of little benefit.
I learned all these little tidbits at the FI-101 class I took at the
API facility. If you really want to know about fuel injection basics
and are within striking distance of Spartanburg, SC ... I'd recommend
it highly. I'm not affiliated, but am a satisfied customer. Smile
Hope this helps.
-- Dwight
pbesing(at)yahoo.com
PostPosted: Tue Apr 18, 2006 8:25 pm    Post subject: Fuel Flow Transducer-Injected Reply with quote
Contrary to the fuel return on my airplane. Not sure
what type of injection it is, but the fuel return is
substantial in flight. I've run 30 mins on the left
tank, and after 30 mins on the right tank, the left
tank is full again.
Paul Besing
Kellym
PostPosted: Tue Apr 18, 2006 9:05 pm    Post subject: Fuel Flow Transducer-Injected Reply with quote
I'm baffled why anyone would bother to run a return line on a Lycoming
powered RV. Certificated aircraft with Lycomings don't use them and
don't have problems. I fly behind an IO-360 without a return line over
100 hours a year. The Bendix RSA injection systems aren't set up for a
return line and don't need one. I don't know about non-certificated
injection systems, but the Bendix system works damn well. I can run lean
of peak no problem with stock injectors to as much as 70LOP. Starting
cold or hot is simple, rarely any difficulty.
tank is full again.
Paul Besing
Kelly McMullen
KCHD
stein(at)steinair.com
PostPosted: Tue Apr 18, 2006 9:22 pm    Post subject: Fuel Flow Transducer-Injected Reply with quote
Wow! What kind of plumbing do you have that allows fuel to be ported back to
a tank that you're not drawing from? Both the Bendix/Precision injection
systems shouldn't port fuel back to any tank during normal flight
operation....even with a purge valve (normally used only for starting and
shutdown) and most of us flying with the old antique Bendix/Precision FI's
don't even have a return line. I know the subies and auto conversions are
different...but...I'm REALLY curious here...do tell!!
Stein.
Bruce(at)glasair.org
PostPosted: Tue Apr 18, 2006 9:39 pm    Post subject: Fuel Flow Transducer-Injected Reply with quote
A return line is to prevent vapor lock and it's a function of how tightly
your engine is cowled. More heat - more problems. So the need for a return
line would vary from airplane to airplane - not by engine/servo type. I have
an IO-540 AA1A5 in my Glasair III and I have a return line. My servo did not
come with one but it was easily added. Fuel stoppage can ruin your whole
day.
Bruce
www.glasair.org
Bob Barrow
PostPosted: Wed Apr 19, 2006 2:23 am    Post subject: Fuel Flow Transducer-Injected Reply with quote
Dan, I thought you put your fuel transducer just after the AFP boost pump on
the cabin floor. Are you now unhappy with the results from that position.
[quote]From: "Dan Checkoway" <dan(at)rvproject.com>
Reply-To: rv-list(at)matronics.com
To: <rv-list(at)matronics.com>
Subject: Re: Fuel Flow Transducer-Injected Date: Tue, 18 Apr 2006
19:16:49 -0700
)_( Dan
RV-7 N714D
PostPosted: Wed Apr 19, 2006 5:03 am    Post subject: Fuel Flow Transducer-Injected Reply with quote
on
I did, and I don't have any problems. But it's not the best location from a
"scientific" standpoint. Wink Pressure drop across the transducer when it's
on the suction side means more chances of vapor lock. And why not put it
where it "matters" most for accuracy? In the metered fuel line is ideal
from what I understand, since it's under positive pressure (as opposed to
suction), and it's measuring the ACTUAL flow of fuel to the cylinders.
Just my 2 cents.
)_( Dan
RV-7 N714D
phil(at)petrasoft.net
PostPosted: Wed Apr 19, 2006 6:12 am    Post subject: Fuel Flow Transducer-Injected Reply with quote
I mounted mine in basically the same position that Dan did except that
mine is further forward and attached to the floor. I plan to move it
this weekend to where Dan put his. I think that the vibration on the
floor is causing it to be WAY off. It shows about 10% higher rate than
what I am actually flowing and turning the boost pump on will give it
another 10% on top of that. With the airplane sitting in the hangar
it's right on the money.
Dan,
How did you attach yours? Is it bolted to something or is the tubing
holding it?
Godspeed,
Phil Birkelbach - Houston Texas
RV-7 N727WB
http://www.myrv7.com
>on
Just my 2 cents.
)_( Dan
RV-7 N714D
PostPosted: Wed Apr 19, 2006 7:52 am    Post subject: Fuel Flow Transducer-Injected Reply with quote
Dont' really know...I've got the cowl off right now
and it's kind of confusing...which is why I asked the
question in the first place...I know that some Cessnas
have this feature (it goes into a 3rd small storage
tank in the cowl) and bonanzas do as well.
So is it my understanding that I do not need this fuel
return? Seems like an aweful lot of fuel to not
return (maybe 1 gallon per hour). The plane was built
17 years ago, and has been that way ever since, with 5
owners, and no problems.
Paul Besing
normal flight
tell!!
Stein.
erichweaver(at)cox.net
PostPosted: Wed Apr 19, 2006 8:18 am    Post subject: Fuel Flow Transducer-Injected Reply with quote
My io-360B1B (vertical induction) from Aerosport Power came with the purge valve installed adjacent to the flow divider. I am tempted to remove it to avoid another fuel line and hole through the firewall, but havent yet.
I was a little surprised to see that everyone had installed the fuel flow transducer in front of the firewall. Not that its bad mind you, just not where I installed mine. Mine is aft of the firewall, between the boost pump and the firewall, where it seems to fit nicely under the cover plate. Now you are all messing with my head making me feel uncomfortable! Anything wrong with my location?
With the exception of the purge line, all the firewall forward fuel lines were pre-made, and supplied with my engine, so I didnt want to waste one of those by adding in the fuel transducer. Since I had to fabricate the fuel lines aft of the firewall anyway, it was an easy decision to put the transducer back there.
Whats really throwing me is that Dan Checkoway's web site shows the transducer back by the fuel booster pump as well (see http://www.rvproject.com/20030520.html). But I see Dan is now recommending the firewall forward location as well? What gives? Somebody is messin' wit my head.
klwerner(at)comcast.net
PostPosted: Wed Apr 19, 2006 8:25 am    Post subject: Fuel Flow Transducer-Injected Reply with quote
Paul,
Would you have any pics on this installation of yours? Like they say: A picture is worth 1000 words.
Konrad
PostPosted: Wed Apr 19, 2006 9:03 am    Post subject: Fuel Flow Transducer-Injected Reply with quote
The one down-side to installing the transducer where Dan his his (and as you
noted he is now suggesting a new location too) is that it puts the transducer
on the suction-side of the engine driven fuel pump. The transducer acts as
a restriction in the line, and my understanding is that if you pull a fluid
through a restriction you will have a pressure drop across the restriction.
Given the rather low vapor pressure of avgas (or, gasoline in general) this
reduces your margin of protection against vapor lock in the feed lines. It
is possible (again, I am not an expert but am simply passing along some of
the things I learned in a fuel injection class) that on a really hot day
vapor could form on the engine-side of the transducer as the engine driven
pump tries to pull fuel. This would be a "Bad Thing (tm)". Smile
Is this guaranteed to happen? No. Clearly many have flown with their fuel
flow transducers on the suction side of the fuel pump without incident. But
once the logic was outlined (and once some vapor pressure graphs were
examined in detail) I have made the decision to install my transducer in
the line between the throttle-body and the flow divider. YMMV.
-- Dwight
Terry Watson
Eric,
I too have an IO-360-B1B with Airflow Performance fuel injection. (You
didn't say who made the fuel injection, but I am assuming it is Airflow
Performance). There was some discussion on this list awhile back about this,
but the purge valve is apparently necessary to shut the engine down. The
engine shutdown checklist says to leave the mixture at full-rich and put the
purge valve control to off position.
Page 21 of my Airflow Performance manual says that when the mixture is at
idle cut-off, there is "approximately 1.0 to 3.0 pph leakage in this
position" which is apparently enough to keep the engine running.
Terry
RV-8A #80729 Baffles
Seattle
PostPosted: Wed Apr 19, 2006 9:12 am    Post subject: Fuel Flow Transducer-Injected Reply with quote
I think that all Dan is saying is that the "Theoretically Perfect"
solution is between the servo and the flow divider, but there are more
practical choices like putting it where you describe. Mine is smack in
the middle of the floor between the boost pump and the firewall. It
doesn't work very well and I'm gonna move it back to where Dan has his
and see if that improves it any. It think it's picking up vibration and
it's causing high readings. That floor shakes pretty good.
BTW you will love that purge valve. I can start mine in two blades when
it's heat soaked, and I like the idea of killing the engine with the
purge valve instead of the mixture. It will completely bleed off the
fuel pressure, so that there is no way fuel can get into the cylinders
while sitting on the ramp. Seems much safer to me. I'd suggest
installing a spring to pull the purge valve closed in case the control
cable breaks. Also make sure that the control cable is of the locking
variety and don't put it next to the cabin heat knob lest ye grab the
wrong one whilst flying, and ruineth thy day.
Godspeed,
RV-7 N727WB
dsvs(at)comcast.net
PostPosted: Wed Apr 19, 2006 9:38 am    Post subject: Fuel Flow Transducer-Injected Reply with quote
-------------- Original message ----------------------
I just talked to the techs at Air Flow Performance. They told me that the best place is between the servo and the purge valve. They also said that the transducer will work fine if you mount it vertically in that line. They claim that they do it all the time. I am going to try it that way and see how it works. They also said to not mount it on the engine. Don
Godspeed,
RV-7 N727WB
http//www.myrv7.com
location?
head.
PostPosted: Wed Apr 19, 2006 10:44 am    Post subject: Fuel Flow Transducer-Injected Reply with quote
holding it?
It's resting on a silicone pad. The tubing is somewhat rigid. Mine is very
accurate with the exception of when the boost pump is running.
)_( Dan
khorton01(at)rogers.com
PostPosted: Wed Apr 19, 2006 10:54 am    Post subject: Fuel Flow Transducer-Injected Reply with quote
Where is that fuel return line coming from?
If it is coming from the fuel injection servo, which make and model
servo is it?
It may be coming from a pressure regulating valve that is part of the
high pressure fuel pump. If that is the case, most people run the
fuel return into a T in the fuel line from the fuel selector valve.
A small number of people use an expensive fuel selector from Andair
that has two valves controlled by one knob. That allows you to send
the return fuel to whatever tank is currently providing fuel, which
avoids the problem of over filling a tank with the return fuel.
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
Goto page 1, 2  Next
Page 1 of 2
