Windscreen Fairing First Look!
Site Admin
PostPosted: Fri Jan 29, 2010 7:52 pm    Post subject: Windscreen Fairing First Look! Reply with quote
Dear Listers,
I've been working hard on the front, fixed fairing around the windscreen this week. Literally, I've been dreading this job more than ANY other on this project. Tonight I sanded though the first layer of electrical tape and in one little spot the second layer started to come up, so I had to pull all of the electrical tape off and so I was able to check out the actual fiberglass fairing after two days of sanding! Yahoo! It came out nearly perfect!! Not bad for creating a fairing out of nothing! The process described in the manual really does work amazingly well. I followed it to the tee up to this point.
Now I have to retape everything, add a layer of resin mixed with filler, then final sand the whole thing. Should be pretty straight forward, but a couple of days worth of work.
Almost done...
RV-8 #82880 N998RV
 Filesize:  126.65 KB
 Viewed:  1141 Time(s)
 Filesize:  129.49 KB
