Gill attachment replacement/fix
javiercarrascob
PostPosted: Thu Jan 28, 2010 8:55 pm    Post subject: Gill attachment replacement/fix Reply with quote
Hello gang!
Hey any advice on how to repair this gill attachment bar?
Or how to replaces them... I'm talking about the thingy that holds the bar in place and that connects to the engine pistons. please see the attached picture.
It broke during a 8 G vertical pull.
JC
how can I fix/replace this?
 Filesize:  69.9 KB
 Viewed:  13346 Time(s)
cjpilot710(at)aol.com
PostPosted: Fri Jan 29, 2010 4:24 am    Post subject: Gill attachment replacement/fix Reply with quote
JC,
You can make the "thingy". It's not that hard. The "thingy" is just an aluminum tube that has had its ends squeezed and bent, than holes drilled at the ends. Its kind of important on how long they are and angles of the bends, but super dup per wise. Any A&P could make one of these "thingy" in less than an hour. HOWEVER I happen to have some of those "thingys" that I could not use when I replaced the gill system on CJ-6. 8Gs???? Man that must have hurt.
Jim "Pappy" Goolsby
N642K
PostPosted: Fri Jan 29, 2010 7:27 am    Post subject: Re: Gill attachment replacement/fix Reply with quote
8 G's? I'd continue to look for broken things and loose rivets. Especially at the belly, center of the wings.
Plus if that was my airplane, from that picture, I'd say I was out of oil. Wink
talew(at)bellsouth.net
PostPosted: Fri Jan 29, 2010 7:36 am    Post subject: Gill attachment replacement/fix Reply with quote
What kind of aircraft did you put the 8g's on ?
Terry
dougsappllc(at)gmail.com
PostPosted: Fri Jan 29, 2010 8:01 am    Post subject: Gill attachment replacement/fix Reply with quote
JC,Send me the length (there are 4-5 different ones on each set of gills) I most likley have them in stock.  8 g's??  You may need more than just a shutter standoff rod...........
Doug
On Thu, Jan 28, 2010 at 8:55 PM, javiercarrascob <javiercarrascob(at)yahoo.com (javiercarrascob(at)yahoo.com)> wrote:
--> Yak-List message posted by: "javiercarrascob" <javiercarrascob(at)yahoo.com (javiercarrascob(at)yahoo.com)>
Hello gang!
JC
http://forums.matronics.com/viewtopic.php?p=283884#283884
http://forums.matronics.com//files/gill_bar_777.jpg
rget="_blank">http://www.matronics.com/Navigator?Yak-List
le, List Admin.
Maybe life is not the party that we were expecting,
but in the mean time, we're here, the band is playing, so we may as well dance....."
Douglas Sapp
Doug Sapp LLC
18B Riverview Road
Omak WA 98841
PH 509-826-4610
Fax 509-826-3644
Noplugs
PostPosted: Fri Jan 29, 2010 6:00 pm    Post subject: Re: Gill attachment replacement/fix Reply with quote
I would like to know where you got that nice looking seal on the outer ring, mine...well I'm embarrassed to call it a seal.
viperdoc(at)mindspring.co
PostPosted: Fri Jan 29, 2010 6:38 pm    Post subject: Gill attachment replacement/fix Reply with quote
Try an aircraft upholstry shop. They can make one for you. The fun part will be mounting it on the ring.
Doc
PostPosted: Sat Jan 30, 2010 8:22 am    Post subject: Gill attachment replacement/fix Reply with quote
I have the new outer ring w/seal in stock for the CJ6, but you would have to change out the metal plates which hold the ends of the gill vane pivot rods.  The CJ6 uses a T type end on the rods, while the Yak uses a C/S straight slot type end.  Other than that difference they are the same.
Doug
On Fri, Jan 29, 2010 at 6:00 PM, Noplugs <qas44n(at)yahoo.com (qas44n(at)yahoo.com)> wrote:
--> Yak-List message posted by: "Noplugs" <qas44n(at)yahoo.com (qas44n(at)yahoo.com)>
http://forums.matronics.com/viewtopic.php?p=283994#283994
le, List Admin.
Douglas Sapp
Doug Sapp LLC
18B Riverview Road
Omak WA 98841
PH 509-826-4610
Fax 509-826-3644
PostPosted: Sat Jan 30, 2010 7:02 pm    Post subject: Gill attachment replacement/fix Reply with quote
Sierra Hotel… I just found a source for the YAK-50 gill axles.
Doc
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of doug sapp
Sent: Saturday, January 30, 2010 10:21 AM
To: yak-list(at)matronics.com
Subject: Re: Re: Gill attachment replacement/fix
Doug
le, List Admin.
Douglas Sapp
Doug Sapp LLC
18B Riverview Road
Omak WA 98841
PH 509-826-4610
Fax 509-826-3644
keithmckinley
PostPosted: Sun Jan 31, 2010 10:17 am    Post subject: Re: Gill attachment replacement/fix Reply with quote
I think the "thingy" connected to the "piston" broke during an 8 G landing.
But that's just me.
javiercarrascob
PostPosted: Sun Jan 31, 2010 7:54 pm    Post subject: Re: Gill attachment replacement/fix Reply with quote
Thank you all for your suggestions!!!
I will try to briefly reply to everyone:
I apologize for not knowing the proper term for the part that I’m seeking (I still don’t)…
The plane is a Yak-55 (build for 9 G’s), and while doing Vertical rolls I normally do the initial pull at 7 or 7.5 G’s. In this Particular time I heard a metallic ping, discontinued flight and after taking the cowlings off I saw the ā€œGill Barā€ broke at the base.
I was also wondering if there was something that looks sturdier (like some 52-TWs) as
Doug suggested.
I’ll have to go next weekend and measure them and I may need a couple.
The nice looking seal on the outer ring came with the plane… sorry 
javiercarrascob
PostPosted: Sun Jan 31, 2010 8:03 pm    Post subject: Gill attachment replacement/fix Reply with quote
Hi Doug Thank you very much,
Let me take the measures next week, how much are the ones that you have?
JC
--- On Fri, 1/29/10, doug sapp <dougsappllc(at)gmail.com> wrote:
Subject: Re: Gill attachment replacement/fix
Date: Friday, January 29, 2010, 11:00 AM
JC, Send me the length (there are 4-5 different ones on each set of gills) I most likley have them in stock. 8 g's?? You may need more than just a shutter standoff rod...........
Doug
Hello gang!
JC
le, List Admin.
Douglas Sapp
Doug Sapp LLC
18B Riverview Road
Omak WA 98841
PH 509-826-4610
Fax 509-826-3644
=nofollow target=_blank>http://www.matronics.com/Navigator?Yak-List
