hagargs(at)earthlink.net Guest
Posted: Tue Apr 18, 2006 1:51 pm Post subject: Good news, bad news |
I took today off as vacation and accomplished quite a bit of Europa work. The plane got its first ride on the dual axel flatbed trailer I fabbed up for it. It went to Falcon Field and back and came out unscathed. (good news) The trailer probably weighs almost 2 times that of the plane and it sits higher than a lot of the traffic. So the plane is protected pretty well. The prop has gotten dynamically balanced and there was a noticeable change even on ground runups. (good news). Initial taxi tests were undertaken and the plane tracks very well. I didn't have to do a bunch of back and forth tap dancing on the rudders to keep it straight on the line as had been my experience in a Cessna 140 and 2 other Europas I had taxied. However being more at ease in my own plane may have led to more measured footwork may account for the better tracking. (good news). On the other hand my low speed taxi was more of a medium speed taxi. With the throttle pulled back to its high i
dle (1500-1600) the taxi rate seemed to be approaching a very fast run by a healthy teenager. Brakes were being dragged almost the whole time. (bad news). I haven't set the prop pitch stops yet on the Airmaster and I hope that is the issue. A very cursory quick check showed about 30 degrees on the backside of the prop and an inability to get up to 5000 rpm on one quick full power run. What are those with Airmasters running for fine pitch?
The weight and balance was completed and the aircraft as it sits now primered for fly off but now final paint has its Cg about 7/10 of an inch behind the forward limit. (good news). I haven't permanately mounted the battery yet. Right now the battery and its box of sorts in sitting centered under the right access panel of the baggage bay shelf. Where are other's CG's at with an empty weight? I need to do the calculations for all the people, baggage, fuel, aux tank combinations to see if I need to do some fine tuning with the location. Now for the (bad news) the empty weight is just about 900 lbs. Which is about 50 lbs more than I was hoping for, 91 % of the weight is on the mono and 9 % on the tailwheel. With some leeway available in the US for certing the gross wt I would like to call it 1420 to get a good solid 500# payload. I can fill it up with gas and still tote a 175# woman around. Just think of what I could carry with a 125# woman aboard . . .! ! ?
I'm 205 sopping wet and I should be 195 so adjusting me should be a lot easier than drilling holes in everything to get more payload. How many out there have their gross weights certificated for greater than 1370?
Steve Haga
A143
Mesa AZ
Getting closer!
Steve Hagar
n9zes(at)verizon.net Guest
Posted: Tue Apr 18, 2006 3:34 pm Post subject: Good news, bad news |
Steve Hagar wrote:
---> I can't speak to the prop pitch issue, but I did just resolve an
idle speed issue with our 140. In the process of getting the idle
mixture sorted (too rich), I ended up with an idle speed of about 800
rpm or even a little more. It would taxi pretty good at 'idle', and
landing was an absolute b!tch!!!! I made some REALLY ugly landings
trying to get it on the ground.
Once we got the idle adjusted to the proper 575 - 600 rpm, it lands like
an absolute pussy cat.
With the high idle, it would float or even climb during the flare,
skitter all around the runway, and even drag the tailwheel for a while
before finally giving up and getting on the ground when trying to do a
3-point landing.
I'm just wondering how much effect idle speed combined with prop pitch
on the Europa might effect the landing ease between different Europas?
Chris
topglock(at)cox.net Guest
Posted: Tue Apr 18, 2006 6:05 pm Post subject: Good news, bad news |
Steve, my tri-gear is certed at 1450 and flys well at that weight.
Empty weight is 925 and CG is almost dead center at 60". With the wife
and I and a full load of fuel, we can carry baggage to gross without
getting out of CG.
I don't remember what the Airmaster is running for fine pitch, and the
book is not handy, but I'm thinking somewhere between 13 and 17 degrees...
Jeff - Baby Blue
166 hours
Steve Hagar wrote:
Steve Haga
A143
Mesa AZ
Getting closer!
Steve Hagar
BEBERRY(at)aol.com Guest
Posted: Tue Apr 18, 2006 11:40 pm Post subject: Good news, bad news |
In a message dated 19/04/2006 00:35:15 GMT Daylight Time, n9zes(at)verizon.net
writes:
Chris - that is really interesting. There is no way that I can get my 914
to idle smoothly at less than about 1400 rpm and indeed in the manual 1700 is
recommended to get a smooth runner. How do you do it??
I am very puzzled as if I adjust the throttle so that I can get below 1400
or so then the engine will stutter and stop and at say 1450 it will just run
but 'misses' and is uneven, which is not good for the weaer on bearings etc.
Enlighten us please.
Patrick
rholder(at)avnet.co.uk Guest
Posted: Wed Apr 19, 2006 12:14 am Post subject: Good news, bad news |
| Quote: | In a message dated 19/04/2006 00:35:15 GMT Daylight
Time, n9zes(at)verizon.net writes:
just resolve an idle speed issue with our 140. In the
process of getting the idle mixture sorted (too rich),
I ended up with an idle speed of about 800 rpm or even
and landing was an absolute b!tch!!!! I made some
REALLY ugly landings trying to get it on the ground.
rpm, it lands like an absolute pussy cat.
BEBERRY(at)aol.com wrote:
| Quote: | Chris - that is really interesting. There is no way
that I can get my 914 to idle smoothly at less than
can get below 1400 or so then the engine will stutter
and stop and at say 1450 it will just run but 'misses'
bearings etc.
Patrick
Patrick - you may find he was talking about a 140 ! A
Cessna 140 which has a Lycoming !
Not a Rotax
Richard
Posted: Wed Apr 19, 2006 1:41 am Post subject: Good news, bad news |
In a message dated 19/04/2006 09:51:50 GMT Daylight Time, josok-e(at)ukolo.fi
writes:
The Europa XS Rotax 914 engine manual issue 8, which i happened to have in
my hands, says quote"You should set the throttle closed stop so that a fully
warmed engine idles at 1200-1400 rpm. Although the engine idles more smoothly
at 1600 rpm or more, when landing the aircraft you will benefit from minimal
residual trust."
Makes sense, and i am thinking of a spring kind of closed throttle stop,
pull to fully close, release to normal 1600 rpm. Would that work?
I think it is good practise to carry out landings and take offs with one
hand firmly on the throttle.. In this case there is no need to have any sort of
automatic system which will give you a reversion to any particular throttle
setting.
Patrick
europa(at)triton.net Guest
Posted: Wed Apr 19, 2006 4:33 am Post subject: Good news, bad news |
Steve,
Sounds like you're getting close.
Be sure you set the prop limit switches. Ours needed a lot of adjustment -
several turns. Seems like we ended up with high limit at 5700 rpm. Also
get a prop tach or something to check your Rotax tach - ours was 300 rpm
off. Perhaps this is your taxi speed problem. We're on grass, and find
that we don't need to use the brakes while taxiing at 1800 rpm.
Our empty weight is 966 lbs and CG is 57.98". We modified John Wigney's
spreadsheet to figure various CG situations. With our figures, using your
200# pilot, you would need to land with 4 gal of fuel.
We used 1500 lbs for our paperwork - remember the quote "what would NTSB
say?" in case of an incident, hence the higher weight. In reality we do not
anticipate loading over 1450. There is a note from Andy concerning CG at
1450 - basically the range is smaller above 1370 lbs ( I have a copy if you
need it).
Jim & Heather Butcher
N241BW still flight testing
Do not archieve
Posted: Wed Apr 19, 2006 4:45 am Post subject: Good news, bad news |
Europa-List message posted by: Richard Holder
Not a Rotax
Richard
--->>> Yes, indeed. Seems I confused a few people by replying regarding our Cessna 140, per the original post regarding C-140 landings along with Rotax idle speed. The C-140 has a Continental C85-12 engine, 85 horsepower.
I was just relating my experience with idle speed and landings to see what sort of relation the Rotax idle has to do with how well the Monowheel, in particular, lands.
With the gear reduction on the Rotax, which is somewhere around 2.7 to 1 IIRC, a 1400 rpm idle gives a little over 500 rpm prop speed. That should be just fine.
Chris
terrys(at)cisco.com Guest
Posted: Wed Apr 19, 2006 9:27 am Post subject: Good news, bad news |
Hi Steve,
Regarding the fine pitch stop, it needs to be adjusted until you can get
about 5700 rpm full throttle, with the airplane tied down (we put a rope
around the tail wheel axle spacers and park a car wheel on the rope).
Ours is set at about 5500-5600 rpm now, which is close enough for us.
Once you get moving a little on take-off, the rpms can rise just a
little more to get to 5700.
For idle speed, we were told by Lockwood that idling below about 1600
rpm can damage the gearbox (this may be more true on the 912S than the
others), so we set our idle at about 1600-1700 rpm. We adjust the idle
speed (and sync) using the idle set screws on the carbs, and then adjust
the throttle cables such that the throttle lever is just off the rear
stop of the lever slot, maybe just a few millimeters. This way, if you
hold the lever back with your hand, you can reduce the idle just a bit
more for landings (by about 50-100 rpm less).
It is true that the higher idle speed will cause the plane to float just
a bit more on landings, but with the Airmaster prop fine pitch adjusted
correctly, we have no problem landing solo with this idle setting.
I suspect your plane is taxiing too fast at the higher idle because the
fine pitch is set too course. Once you get the fine pitch set
correctly, you may find that the taxi speed is more acceptable at idle.
I guess another problem could be your tachometer accuracy. We verified
ours with an optical prop tach designed for model airplane use.
Terry Seaver
A135 / N135TD
XS Mono with 912S and Airmaster.
SPurpura(at)aol.com Guest
Posted: Wed Apr 19, 2006 3:49 pm Post subject: Good news, bad news |
I hear the 914 gear box will last longer and it idles smoother if you idle
about 2000rpm,my throttles will pull back to 1500 rpm whitch I use on short
final to minimize the float but I bring the rpm's back up to 2000 rpm before
leaving the runway.
Sam N77EU
