scottmschmidt(at)yahoo.co Guest
Posted: Wed Jan 27, 2010 9:09 pm Post subject: Possible Door Handle Solution |
Did any of you notice this door handle.
I am pretty impressed with this one. It does not address the case of accidentally opening the door in flight but I'm not sure if a door has been lost because of that.
Looks like you can purchase the set for $300.
Very simple and easily retrofit-able to the flying RV's with the standard door handle.
http://www.vansairforce.com/community/showthread.php?t=53564
Scott Schmidtscottmschmidt(at)yahoo.com
Deems Davis
Posted: Wed Jan 27, 2010 9:27 pm Post subject: Possible Door Handle Solution |
I saw this, and like it, I've got Coss handles and latches (similar to Hendrcks). And I think I could easily adapt this to my "Finished" airplane. So far this is the only 'solution' I've seen that I will consider. IT seems that the one item that is uncertain is whether the extra latch/catch is far enough aft to seal the deal.
Deems Davis
N519PJ
www.deemsrv10.com
On 1/27/2010 10:07 PM, Scott Schmidt wrote: [quote] Did any of you notice this door handle.
Scott Schmidt scottmschmidt(at)yahoo.com (scottmschmidt(at)yahoo.com)
| [b]
